Flexibility issues with NIC movements in and out of Virtual Switches | Nutanix Community
focaccio
I’m getting failed when I try to move some physical NICs back into a virtual switch.
Will I need to do something manually?
Here is the error:
Failed to apply Virtual Switch config on canary node, error: Failed to apply virtual switch config on the host:8f1ac7f1-fb84-4ec5-ade4-96365016f570. update_bridge_bond ERROR: Adding bond:[{'bond_type': 'balance-tcp', 'interfaces': ['eth3', 'eth4'], 'lacp': 'active', 'mtu': 1500, 'name': 'br1-up', 'other_config': {'lacp-fallback-ab': True, 'lacp-time': 'fast'}}] to bridge:br1.
Exception("Command failed: ovs-vsctl add-bond br1 br1-up eth3 eth4 bond_mode=balance-tcp lacp=active other_config:lacp-fallback-ab=True other_config:lacp-time=fast: b'ovs-vsctl: cannot create a port named br1-up because a bridge named br1-up already exists\n'",)
My goal is to move eth3 and eth4 into a br1-up under vs1.
Be the first to reply!
