Hello.
I detected a problem using the latest kernel 6.1.0.-25-amd64 with all my VMs under Nutanix.
I recently upgraded all my Debian servers from version 12.6 to 12.7: in version 12.6 the linux kernel in use was 6.1.0-23-amd64 and in version 12.7 is 6.1.0-25-amd64.
The issue is related with the download speed using this kernel in all my upgraded VM’s. It’s extremely slow. So after 2 days trying to figure out what was happening (installing debian 12.7 in a new VM same problem....installing in VirtualBox no problem at all), so I decided to rollback to the old kernel, maintaining the Debian version 12.7 (with kernel 6.1.0-23-amd64) and the problem stopped.
I’m using the following system, see picture:
Here are some speed tests:
Debian version 12.6:
wget https://proof.ovh.net/files/100Mb.dat
--2024-09-05 01:26:12-- https://proof.ovh.net/files/100Mb.dat
Resolviendo proof.ovh.net (proof.ovh.net)... 141.95.207.211, 2001:41d0:242:d300::
Conectando con proof.ovh.net (proof.ovh.net)[141.95.207.211]:443... conectado.
Grabando a: «100Mb.dat.2»
100Mb.dat.2 100%[=======================>] 100,00M 29,2MB/s en 3,6s
2024-09-05 01:26:16 (28,0 MB/s) - «100Mb.dat.2» guardado [104857600/104857600]
Debian versión 12.7:
--2024-09-05 01:17:06-- https://proof.ovh.net/files/100Mb.dat
Petición HTTP enviada, esperando respuesta... 200 OK
Longitud: 104857600 (100M) [application/octet-stream]
Grabando a: «100Mb.dat.1»
100Mb.dat.1 2%[==== ] 2,13M 193KB/s eta 7m 35s
Example of speed test of VM running in same node and debian 11.10:
Idle Latency: 16.98 ms (jitter: 0.08ms, low: 16.96ms, high: 17.11ms)
Download: 2825.49 Mbps (data used: 3.0 GB)
Upload: 1832.95 Mbps (data used: 3.3 GB)
Result URL: https://www.speedtest.net/result/c/4491d7ea-a293-402f-9597-9b08de9a3846
Example of speed test of VM running in same node and debian 12.7 (see Download speed):
Download: 8.43 Mbps (data used: 10.1 MB)
Upload: 2281.23 Mbps (data used: 4.0 GB)
Result URL: https://www.speedtest.net/result/c/d1d656ac-5c26-476c-819c-0b9448ca05b3
Maybe a bug or something with the hypervisor?
Thank you.
