What is the maximum number of playbooks that can be supported by Prism Central? | Nutanix Community
  • January 25, 2023
  • 103 views
I'm curious, what is the maximum number of Playbooks that can be supported by Prism Central?
And how many actions we can add in one playbook?
Best answer by laura_jordana
Hi, it’s documented in the Config Maximums here: https://portal.nutanix.com/page/documents/configuration-maximum/list?software=NCM%20Prism%20Ops&version=pc.2022.6
It’s 85 playbooks and 25 actions per playbook
However - you could actually have more playbooks than this, if you had less actions per playbook.
laura_jordana
  • January 25, 2023
  • January 25, 2023
Thank you Laura😀
