Deleting disk image | Nutanix Community
Deleting disk image
  • April 9, 2021
  • 459 views
I migrated 2 linux servers from Xen Citrix successfully. In the image configuration, can I delete the disk images or if I do that the VM will no longer function.
Best answer by JacksonWrath1607
Yea, if you created the VMs’ disks by cloning from the images you imported, you can delete the images. The CVM will keep the data that’s still being used by the VM.
JacksonWrath1607
