I used Rest API V1 to get the VM information. There is information named stats in the acquired information. But I can't find a description of the items in stats. Does anyone know the website or any information that has this information?
Contents of the stats item in Rest API V1
Best answer by Alona
Hi there!
Go to Prism Element REST API Explorer (gear icon dropdown) and at the top right corner choose API v1 version.
v1/vms/ will give you an example of stats (interpreting them is a different story):
"stats": {
"hypervisor_avg_io_latency_usecs": "0",
"num_read_iops": "-1",
"hypervisor_write_io_bandwidth_kBps": "0",
"timespan_usecs": "-1",
"controller_num_read_iops": "0",
"controller.storage_tier.ssd.usage_bytes": "756051968",
"read_io_ppm": "-1",
"controller_num_iops": "0",
"hypervisor_memory_assigned_bytes": "-1",
"total_read_io_time_usecs": "-1",
"controller_total_read_io_time_usecs": "0",
"controller.storage_tier.ssd.configured_pinned_bytes": "0",
"hypervisor_num_io": "0",
"controller_total_transformed_usage_bytes": "0",
"hypervisor_cpu_usage_ppm": "25226",
"controller_num_write_io": "1",
"avg_read_io_latency_usecs": "-1",
"guest.memory_swapped_in_bytes": "0",
"controller_total_io_time_usecs": "1022",
"memory_usage_ppm": "87138",
"controller_total_read_io_size_kbytes": "0",
"controller_num_seq_io": "-1",
"controller_read_io_ppm": "0",
"controller_total_io_size_kbytes": "4",
"hypervisor.cpu_ready_time_ppm": "231",
"controller_num_io": "1",
"hypervisor_avg_read_io_latency_usecs": "0",
"num_write_iops": "-1",
"controller_num_random_io": "0",
"num_iops": "-1",
"guest.memory_usage_ppm": "87138",
"hypervisor_num_read_io": "0",
"hypervisor_total_read_io_time_usecs": "0",
"controller_avg_io_latency_usecs": "1022",
"num_io": "-1",
"controller_num_read_io": "0",
"hypervisor_num_write_io": "0",
"controller_seq_io_ppm": "-1",
"guest.memory_usage_bytes": "711401472",
"controller_read_io_bandwidth_kBps": "0",
"controller_io_bandwidth_kBps": "0",
"hypervisor_num_received_bytes": "59617",
"hypervisor_timespan_usecs": "44193851",
"hypervisor_num_write_iops": "0",
"total_read_io_size_kbytes": "-1",
"hypervisor_total_io_size_kbytes": "0",
"avg_io_latency_usecs": "-1",
"hypervisor_num_read_iops": "0",
"hypervisor_swap_in_rate_kBps": "-1",
"controller_write_io_bandwidth_kBps": "0",
"controller_write_io_ppm": "1000000",
"controller_user_bytes": "48842076160",
"hypervisor_avg_write_io_latency_usecs": "0",
"hypervisor_num_transmitted_bytes": "444",
"hypervisor_total_read_io_size_kbytes": "0",
"read_io_bandwidth_kBps": "-1",
"guest.memory_swapped_out_bytes": "0",
"hypervisor_memory_usage_ppm": "1000000",
"hypervisor_num_iops": "0",
"hypervisor_io_bandwidth_kBps": "0",
"controller_num_write_iops": "0",
"total_io_time_usecs": "-1",
"controller_random_io_ppm": "-1",
"controller.storage_tier.das-sata.usage_bytes": "83346403328",
"controller_avg_read_io_size_kbytes": "0",
"hypervisor_swap_out_rate_kBps": "-1",
"total_transformed_usage_bytes": "-1",
"avg_write_io_latency_usecs": "-1",
"num_read_io": "-1",
"write_io_bandwidth_kBps": "-1",
"hypervisor_read_io_bandwidth_kBps": "0",
"hypervisor_consumed_memory_bytes": "-1",
"random_io_ppm": "-1",
"total_untransformed_usage_bytes": "-1",
"hypervisor_total_io_time_usecs": "0",
"num_random_io": "-1",
"controller_avg_write_io_size_kbytes": "4",
"controller_avg_read_io_latency_usecs": "0",
"controller.storage_tier.das-sata.configured_pinned_bytes": "0",
"num_write_io": "-1",
"total_io_size_kbytes": "-1",
"controller.storage_tier.cloud.usage_bytes": "0",
"io_bandwidth_kBps": "-1",
"controller_timespan_usecs": "30000000",
"num_seq_io": "-1",
"seq_io_ppm": "-1",
"write_io_ppm": "-1",
"controller_avg_write_io_latency_usecs": "1022"
