NGT on Debian 10 , when? | Nutanix Community
  • September 13, 2020
  • 1010 views
I have a lot of virtual machines running with latest Debian 10 distribution (version 10.2 and next 10.5).
When will be available Nutanix Guest Tools for this distribution? It’s a mess to receive warnings everyday with the message of NGT not installed in these machines.
Best answer by AnishWalia20
Hey @veiga , I researched internally and found that currently a feature request for this functionality is open and engineering is still working to add this and currently they are gathering requirements for this.
As of now, there is no ETA for this functionality.
If the warnings are irritating, you can also go ahead and disable the alert from the alert configuration menu on prism elment.
AnishWalia20
  • 201 replies
  • September 14, 2020
