Removal of orphaned snapshots | Nutanix Community
Trying the veeam AHV appliance, i had a crash whilst taking a backup
now am left with orphaned snapshots on a PAID ACCOUNT, and nutanix sends the ball to veeam back to nutanix, so here i am
Protection Domain DP-QC-3 has 3 aged third-party backup snapshot(s) and may unnecessarily consume storage space in the cluster.
i have a multitude of these and want to manually remove those snapshots, is there a process for this ?
Best answer by tbcconstruction
solution:
get all vm uuids
grab snapshots with thos in mind.. with api
curl -u "admin" -k -X POST --header 'Content-Type: application/json' --data '{"filter":"entity_uuid==UUIDHERE","kind":"vm_snapshot"}' 'https://1.2.3.4:9440/api/nutanix/v3/vm_snapshots/list
find one with furthest date or to delete and use api to delete.
curl -u admin -k -X DELETE --header 'Content-Type: application/json' --header 'Accept: application/json' 'https://1.2.3.4:9440/api/nutanix/v3/vm_snapshots/SNAPIDHERE
aluciani
Forum|alt.badge.img+34
  • Chevalier
  • 348 replies
  • August 19, 2018
Hi @tbcconstruction
I see you posted this in the community edition (CE) forum. Are you using CE with the Veeam appliance or the commercial version of Nutanix? Let me know 👍
Forum|alt.badge.img+16
  • 588 replies
  • August 20, 2018
Thread with steps how to remove orphaned snapshots: https://next.nutanix.com/discussion-forum-14/how-to-remove-orphaned-snapshots-27625
commercial both
Protection Domain DP-QC-2 has 5 aged third-party backup snapshot(s) and may unnecessarily consume storage space in the cluster.
Protection Domain DP-QC-1 has 6 aged third-party backup snapshot(s) and may unnecessarily consume storage space in the cluster.
Protection Domain Dp-QC-4 has 1 aged third-party backup snapshot(s) and may unnecessarily consume storage space in the cluster.
so its not snapshots but third party ones ill try the same solution to try to ident
aluciani
  • Chevalier
  • 348 replies
  • August 20, 2018
Thanks @tbcconstruction
Looks like you posted this in the community edition (CE) forum, I'll move it to the backup and recovery forum. Also check out this post - [HowTo] I'm new here, how do I get started? Give you a sense of the landscape. Thanks 👍
aluciani
  • Chevalier
  • 348 replies
  • August 20, 2018
Did the post from @Primzy help?
aluciani
  • Chevalier
  • 348 replies
  • August 20, 2018
Hi @tbcconstruction
Do you have a Veeam support case #? You can private message me and I can help push this along. Thanks
aluciani wrote:
Hi @tbcconstruction
just got an answer they will get back to me wednesday...
aluciani
  • Chevalier
  • 348 replies
  • August 21, 2018
Be great if you could also add the solution to this thread for others to follow when you hear smothing. 👍
will do
solution:
get all vm uuids
  • February 6, 2020
Cant find the aged third party snapshots using this method. Any hints about how to get a list of these snapshots?
