Hi Anyone have a playbook that I can use accomplish the subject feat? I have to power cycle 470 VMs in groups. i.e Group1 has 45 VMs, Group2 has 45 vms and so on.
PLAYBOOK TO POWER CYCLE VMS OFF AND BACK ON
Best answer by Freire
If you have Prism Central, you can reboot the VMs by going to the VMs view, filtering them by category or host to group them, or simply sorting them by name and selecting them page by page. Then, go to Actions and choose Power Cycle.
It’s a bit manual, but if you don’t want to use any external tools or APIs, it works just fine.
Hope that helps!
