Compatibility Check: Upgrading Nutanix NX-1465-G5 to AOS 6.10 | Nutanix Community
Hey,
I have some older Nutanix hardware: the NX-1465-G5. It’s currently running an outdated version of AOS. I’m looking to reinstall the appliance with version 6.10. Is the G5 model compatible with AOS 6.10? Is there compatibility for my equipment?
Thanks!
Best answer by JeroenTielen
You can run CE on it and then upgrade that to 6.10.
  • 1351 replies
  • October 21, 2024
  • October 22, 2024
I download phoenix and create bootable with rufus as explained in  How to Install Community Edition Episode 1 | Nutanix University (youtube.com).
  1. Do I need VirtoIO also?
Each node in my NX-1045-G5 appliance has:
USB 2 × USB 3.0 (on-board)
VGA 1 × VGA connector per node (15 pin female)
Since I connect directly with screen monitor and keyboard.
Therefore, I have only 1 USB slot available, I plug only the phoenix USB.
  1. It is possible to run CE with only USB pluged-in each time?
But now I get this error:
Eviatar Shaul
to install CE, you will need SSD and normal HDD (hot and cold storage).you can install the CE via bootable USB to your hardware.(SSD and HDD).
  • 1351 replies
  • October 28, 2024
  • October 29, 2024
I succeeded to install AOS 6.10 and compatible AHV on my Nutanix appliance and form a cluster with Foundation tool.
But now I have 1 node that do not join to the cluster, it still in CE and do not upgrade well. Is there a way to upgrade separately that node to expand the cluster (to work with all 4 nodes that I have)?
  • 1351 replies
  • October 29, 2024
Reinstall that specific node with ce, create a single node cluster from it. Upgrade to the same version as your existing cluster. Then destroy the single node cluster and expand the existing with this node.
  • October 29, 2024
That Fix my problem. Thanks a lot!
Balduz84
  • November 21, 2024
I have written a guide to force updates into not supported hardware:
https://www.silviobalduzzi.com/2024/10/aggiornare-nutanix-su-hw-non-piu-supportato/
Obviously, the procedure is not supported 😀
Silvio
  • 1351 replies
  • November 21, 2024
Balduz84 wrote:
Silvio
Here is a guide to do it via the gui/lcm ;) easier ;) https://www.jeroentielen.nl/trying-to-get-my-oldest-to-the-latest-and-running-the-latest-%f0%9f%ab%a3/
Balduz84
  • November 21, 2024
JeroenTielen wrote:
Balduz84 wrote:
Silvio
Your guide is for the Community Edition, but my guide is dedicated to the complete version. 😁
  • 1351 replies
  • November 21, 2024
Balduz84 wrote:
JeroenTielen wrote:
Balduz84 wrote:
Silvio
Works the same ;)
