NCC completes 100%, status changes to cancelled, seeking issue resolution | Nutanix Community
When I run NCC, it complete 100% after that the status changed to cancelled instead of success. What could be the issue ?
-JAI
Best answer by Jayakumar
It got resolved after upgraded the NCC, but in one of my cluster I am not able to see the NCC option under Upgrade software page in PE but I can see under LCM ? Why it is not showing under Upgrade Software page?
-JAI
sl.farhanparkar
HI,
had you restarted cluster health service, or updated the NCC.
F>P
  • Trendsetter
  • 44 replies
  • October 24, 2023
No,  What is the command to restart ?
-JAI
  • 1393 replies
  • October 24, 2023
genesis stop cluster_health
cluster start
  • Trendsetter
  • 44 replies
  • November 3, 2023
-JAI
sl.farhanparkar
All the updates are going to be managed though LCM only, in future the software updates option will be depreciated from settings and all the updates will be managed only through LCM.
