I’ve been trying to create webhooks using Nutanix API V3 (using Nutanix API explorer) and it works fine. The only problem I’ve been getting is to send some custom parameters along with the payload.
Let’s say I want to send a custom parameter named cluster ip and value is “10.247.xxx.xx”. It’s just an example, but I want to receive this custom parameter whenever the event is triggered (so basically send this when event is sent to my webhook URL). I’ve tried googling it but no use. I cannot seem to find anything in documentation as well.
Is there anyone WHO can help me with this?
Nutanix Rest Api V3 - Webhook Custom Parameters
