Single Node Cluster SATADOM Repair | Nutanix Community
  • September 15, 2022
  • 814 views
Is it possible to recover single node cluster after SATADOM crash? How can I reimage it?
Best answer by Vyacheslav
I have recovered crashed cluster, special thanks to Alexander (@Kargozia).
recovery instructions:
  1. deploy single node nutanix ce cluster on the same hardware, get boot device img
  2. write boot device img to ssd (do not use usb flash for boot), boot crashed single node cluster from this ssd
  3. fix AHV network settings (fix ifcfg scripts, fix open vswitch bridge). Make sure the network is working and you have ssh access to AHV
  4. fix CVM xml config (/etc/libvirt/qemu/NTNX-xxx-CVM.xml). You need to fix block devices info (all info in tags <disk device="disk" type="block">, fix count of disks and their id’s).
    Disk info:
    - lsblk
    - ls -la /dev/disk/by-id/
    udevadm info --query=all --name=/dev/sdx
  5. Reload changes - virsh define /etc/libvirt/qemu/NTNX-xxx-CVM.xml. Boot CVM, make sure you have ssh access to CVM (192.168.5.2)
  6. Get ssh access to CVM, fix open vswitch uplinks.
  7. Exec genesis start from CVM, check that everything is ok (if not - just read the logs and fix something)
  8. Create boot device backup
Moustafa Hindawi
This KB would help
https://portal.nutanix.com/page/documents/kbs/details?targetId=kA03200000098YlCAI (support portal login required)
  • September 19, 2022
Thanks, but I don’t have access
    Disk info:
    - lsblk
Keep in mind that for some reason nutanix installer truncate disk serial number (tag <serial></serial> in CVM xml config) to 16 characters.
