AOS 5.20.4.6 to AOS 6.5 | Nutanix Community
AOS 5.20.4.6 does not support direct upgrade to AOS 6.5. Will an over-upgrade package be released later?
Best answer by Sergei Ivanov
There will be a 6.5.1 release fairly soon and it will be possible to upgrade to it from 5.20.4.6.
Sergei Ivanov
  • 108 replies
  • August 8, 2022
  • September 7, 2022
Any update on this? Still no path to 6.5 and I really want the benefits of the database optimizations in 6.5. Thank you in advance.
