i wants to Migrate VMs from AHV cluster to AHV Cluster | Nutanix Community
  • August 4, 2022
  • 44 views
i wants to Migrate VMs from AHV cluster to AHV Cluster, my Source AHV Cluster running on AOS 5.20.0.1 LTS and destination cluster running on 5.20.3.5 LTS, so can configure Data protection and migrate VMs from source ahv cluster to destination ahv cluster with mismatch AOS version.?
Best answer by JeroenTielen
This is from the documentation:
  • Try to keep both sites at the same AOS version. If both sites require compression, both must have the compression feature licensed and enabled.
 https://portal.nutanix.com/page/documents/solutions/details?targetId=BP-2005-Data-Protection:BP-2005-Data-Protection
  • 1351 replies
  • August 4, 2022
