Migrate Users Windows VMs from AHV to VMware Esxi | Nutanix Community
Hi.
I’m looking for some experiences in migrating windows user vms from acropolis hypervisor to vmware esxi.
I tried and followed severals KBs and articles but none were successful.
After powering on windows VM on esxi, they immediately go to the famous “blue screen” and don’t recognize the disk.
Articles that I followed:
https://portal.nutanix.com/page/documents/kbs/details?targetId=kA032000000PMcKCAW
https://portal.nutanix.com/page/documents/kbs/details?targetId=kA03200000098T7CAI
https://portal.nutanix.com/page/documents/details?targetId=Prism-Central-Guide-Prism-v5_19:mul-vm-export-as-ova-pc-t.html
https://next.nutanix.com/move-application-migration-19/want-to-export-a-vm-from-ahv-here-s-how-37275
Has anyone has experience with this ? Can you help me ?
Best regards
Best answer by rohan.saksena-55595
Hello Luis,
Did you refer to following link: https://portal.nutanix.com/page/documents/kbs/details?targetId=kA00e000000CtlXCAS
Rohan Saksena
You need to use vmware converter for this. And before you convert the machine install vmware tools in it. Make sure that if source vm is bios or uefi that the target vm is the same.
  • March 23, 2022
Hi Jeroen.
Already tried these options,
First, I can’t install VMware tool because this error “VMware Tools can only be installed on virtual machines”
And VMware converter shows me the following error “ A file I/O error occurred while accessing “. and some logs like “Opening virtual disk failed with error” , “Failed to retrieve the storage mapping with error converter”
  • March 28, 2022
I’m in a similar situation, looking for a viable option to migrate several hundred VM’s from AHV to ESXi (non-nutanix cluster).
Does anyone know if Starwind P2V or V2V would work for this since VMware Converter isn’t technically available any more?
rohan.saksena-55595
Hello Luis,
Rohan Saksena
