LCM precheck failed | Nutanix Community
LCM precheck failed
Tural
Hello Nutanix community. I have problem with upgrading my AHV version. I attached error screenshot. How can i solve this problem without any power off, reboot or other actions? Because it production environment. Thanks
Best answer by bcaballero
Hi there @Tural
Did you expand your cluster with nodes containing “older” CPU than the original ones? For Example if your cluster were using G6 Nodes, Did you add some G5 nodes? or different Gen Xeon Processors?
If the answer is yes, you need to power cycle (not reboot) every single VM running in the cluster to “adopt” to lower CPU features, if you don’t do this that UVM’s will not be able to migrate from a G6 node to a G5 or from “newer” Xeon node to “older”. This is called EVC in VMWare environments.
Here’s a topic with a similar issue https://next.nutanix.com/how-it-works-22/living-migration-between-old-and-new-processors-39360
I’m afraid that the KB that @Primzy suggested you it’s the only way to go. Anyway, you can still open a case for clarification.
Hope this helps
Regards!
  • May 7, 2021
I think Nutanix must to help with this issue.
Forum|alt.badge.img+16
  • 588 replies
  • May 7, 2021
Here is the KB 6409 hopefully you find something useful here: Pre-Upgrade Check: test_cluster_config
bcaballero
  • Guardian
  • 186 replies
  • May 10, 2021
Hi there @Tural
Hope this helps
Regards!
