Minimum Permissions Required for Karbon kubectl Access? | Nutanix Community
  • February 16, 2021
  • 174 views
I need to create a role that will be able to get the 24 hour certificate to be able to run `kubectl` calls against Karbon.
When I look at the role creation page, there are a lot of options there.  I am a bit overwhelmed in trying to figure out what permissions I need to just grant this one function.
What permissions are needed for a user to be able to get the 24 hour certificate to be able to run `kubectl` commands?
Best answer by Vaccano
Turns out there is more than one place to set the permissions and roles.
If you follow the instructions half way down this page it shows how to add a user as a “viewer”.  Once done, they have access to the karbon enough to get a certificate and run kubectl.
  • February 16, 2021
AnishWalia20
  • 201 replies
  • February 18, 2021
Hey @Vaccano thanks a lot for sharing it with us. :smile:
