Explain the function of the command “nodetool -h 0 ring” | Nutanix Community
  • January 6, 2021
  • 1965 views
Can anyone explain the function of the command “nodetool -h 0 ring” and also the explanation of its output, because I often see nutanix support using this command, i just curious function this command :D
Best answer by Primzy
More info can be found here: Cassandra information using nodetool
Forum|alt.badge.img+16
  • 588 replies
  • January 6, 2021
This command will produce a very long output of all tokens (primary key hashes) on a given node.
  • 588 replies
  • January 6, 2021
Thanks for your answer.
