unable to script acli commands? | Nutanix Community
  • September 14, 2020
  • 1574 views
Getting this error when I try to use putty/plink for any ACLI-related command:
bash: ACLI: command not found
Doesn't seem to matter what acli “command” i run, even just running “acli” by its self gives the same error. I am able to run commands like “hostname” etc using plink/putty on the CVM. Feel like im missing something very simple here.
Example command:
putty $cvmIP -l $username -pw $password “acli vm.disk_get $vmname disk_addr=scsi.0”
Best answer by Dominix_pf
try to give putty the fullpath to your command:
putty $cvmIP -l $username -pw $password “/usr/local/nutanix/bin/acli host.list”
Dominix_pf
  • 23 replies
  • September 15, 2020
Nailed it. Thank you!
