NCP 5.10 Exam - Issues with PSI Video Streaming | Nutanix Community
What are the ways to fix a denied - PSI Video Streaming - Denied
check item that is needed prior to taking the Nutanix University Exam.
I have issue withe just 1 item that is not passing(Denied) the compatibility check
prior to taking the NCP 5.10 exam
Some times it passes but some times it does not.
And because of this was unable to start my exam today.
PSI Services LLC worked remotely with me but the compatibility check
did not pass.
Later in the day when I ran the check, It passes then few minutes later
it fails again.
I don't have an issues with Zoom/Webex and many other applications
its just this application,
And I also can not get the PSI secure browser to start to install
and can not find any info at which point this software gets installed?
Best answer by rahul.khandalkar
Send your queries at education@nutanix.com
  • March 13, 2021
hello, i solved the same issue in windows 10 just turning off and turning on the camera and the microphone in the control panel.
