SNMP Alerts Message Format | Nutanix Community
Recently my customer is configuring snmp monitoring in their infrastructure to monitor their nutanix clusters. As their Administrators are trying to capture keywords from the snmp traps, they found that the snmp trap messages and the alerts messages found in the web console guide are different. Is there a document which can help to indicate what are the exact snmp trap messages /format for the different alerts sent?
  • 13 replies
  • June 17, 2020
  • June 18, 2020
Thanks @Tapati
I have the documents as per recommended. Just like to check, the alert messages that is captured on the Prism will be the same as the SNMP trap messages?
  • 13 replies
  • July 6, 2020
Hello @LeonardThng
SNMP trap messages may not be exactly the same as the alert messages that are captured on the Prism
SNMP trap messages will be based on the format in the MIB file
https://portal.nutanix.com/page/documents/details/?targetId=Web-Console-Guide-Prism-v5_17%3Aman-nutanix-mib-r.html
Also SNMP is not for alerts, its for Monitoring the stats or status
