If you use balance-slb, how does one figure out which physical is being used by one VM ?
For instance, with ESXi I’d run esxtop, and I can see which physical nic is being “mapped” to my virtual nic. Is it possible with AHV? If yes how ?
I think it is important when you troubleshoot.
