iam-proxy.ntnx-baseが表示されてPrism Centralにログインできない件 | Nutanix Community
  • November 20, 2024
  • 9 replies
  • 243 views
Prism Centralのpc.2024.2でデプロイしました。
1日後に再度Prismからログインを行うと、iam-proxy.ntnx-baseと表示されており
認証情報を入力しても、server is not reachableと表示されてログインできません。
clusterのstopとstart、PCVMの再起動などを行ってみましたがどれもだめでした。
Prism central unreachable | Nutanix Community
でも問い合わせされている方がいらっしゃいましたが、解決策は書かれておらず。
どなたか助けてください!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
DylanH
  • Trendsetter
  • 46 replies
  • November 20, 2024
Could you please send me the results outs of theses commands please :
  • ncli -h true
  • nuclei user.list
  • Check if there is any error in /home/data/nutanix/logs/aplos.out (cat /home/data/nutanix/logs/aplos.out | grep “ERROR”)
  • nslookup iam-proxy.ntnx-base
  • mspctl cluster health
  • sudo kubectl get pods -A
  • docker plugin ls
Thanks.
  • 15 replies
  • November 21, 2024
Thank you for your fast reply.
Paste the result that some commands you tell me below.
①ncli -h true
HTTP 500 Internal Server Error
②nuclei user.list
2024/11/21 01:18:39 ZK : Initiating connection to server 192.168.0.110:9876
2024/11/21 01:18:39 ZK : Connected to 192.168.0.110:9876
2024/11/21 01:18:39 ZK : Authenticating connection 0x0
2024/11/21 01:18:39 nuclei is attempting to connect to Zookeeper
2024/11/21 01:18:39 Parsed cluster id: 1106392137852969902 and cluster incarnation id: 1215556561207248468 from /home/nutanix/config/zookeeper/cluster_identifier.json
2024/11/21 01:18:39 ZK : Authenticated: id=0x1934a1195ac1cf6, timeout=20000
  "message": {
    "api_version": "3.1",
    "code": 500,
    "message_list": [
        "message": "Internal Server Error. Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/authz/v1/authorize after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>",
        "reason": "INTERNAL_ERROR"
    "state": "ERROR"
  • 15 replies
  • November 21, 2024
③cat /home/nutanix/data/logs/aplos.out | grep "ERROR"
111uclei user.list-h truedocker plugin lssudo kubectl get pods -Amspctl cluster healthnslookup iam-proxy.ntnx-basecat /home/nutanix/data/logs/aplos.out | grep "ERROR"
ERROR:root:Trying to access flag zeus_config_cache_path before flags were parsed.
ERROR:root:Trying to access flag anduril_cap_cache_entry_ttl_secs before flags were parsed.
ERROR:root:Trying to access flag anduril_cap_cache_size before flags were parsed.
ERROR:root:Trying to access flag anduril_client_cache_size before flags were parsed.
ERROR:root:Trying to access flag sdk_cfs_ip before flags were parsed.
ERROR:root:Trying to access flag sdk_cfs_port before flags were parsed.
ERROR:root:Trying to access flag rpc_retry_timeout_sec before flags were parsed.
ERROR:root:Trying to access flag enable_rpc_failure_error_logging before flags were parsed.
2024-11-20 15:32:07,983Z ERROR base_hypervisor.py:120 Network interface eth1 has unexpected network driver vxlan
2024-11-20 15:32:55,037Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/v4.0.a2/authn/directory-services after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-20 15:32:55,041Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-20 15:33:27,528Z ERROR service_jwt_tokens.py:39 IAM token validation failed with Signature verification failed
2024-11-20 15:33:34,548Z ERROR service_jwt_tokens.py:39 IAM token validation failed with Signature verification failed
2024-11-20 15:33:40,740Z ERROR service_jwt_tokens.py:39 IAM token validation failed with Signature verification failed
2024-11-20 15:33:42,377Z ERROR service_jwt_tokens.py:39 IAM token validation failed with Signature verification failed
2024-11-20 15:33:58,674Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/v4.0.a2/authn/directory-services after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-20 15:33:58,676Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-20 15:34:29,969Z ERROR service_jwt_tokens.py:39 IAM token validation failed with Signature verification failed
2024-11-20 15:35:02,742Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/v4.0.a2/authn/directory-services after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-20 15:35:02,745Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-20 15:35:22,488Z ERROR athena_auth.py:272 Authentication failed Invalid CA chain from the cluster
2024-11-20 15:35:22,490Z ERROR athena_auth.py:179 Server encountered unexpected condition. Error: Traceback (most recent call last):
 'code': <HTTPStatus.INTERNAL_SERVER_ERROR: 500>,
                   'reason': 'INTERNAL_ERROR'}],
 'state': 'ERROR'}
2024-11-20 15:35:22,499Z ERROR auth.py:100 Traceback (most recent call last):
 'state': 'ERROR'}
2024-11-20 15:35:27,550Z ERROR athena_auth.py:272 Authentication failed Invalid CA chain from the cluster
2024-11-20 15:35:27,552Z ERROR athena_auth.py:179 Server encountered unexpected condition. Error: Traceback (most recent call last):
 'state': 'ERROR'}
2024-11-20 15:35:27,558Z ERROR auth.py:100 Traceback (most recent call last):
 'state': 'ERROR'}
2024-11-20 15:35:32,616Z ERROR athena_auth.py:272 Authentication failed Invalid CA chain from the cluster
2024-11-20 15:35:32,622Z ERROR athena_auth.py:179 Server encountered unexpected condition. Error: Traceback (most recent call last):
 'state': 'ERROR'}
2024-11-20 15:35:32,627Z ERROR auth.py:100 Traceback (most recent call last):
 'state': 'ERROR'}
2024-11-20 15:35:37,691Z ERROR athena_auth.py:272 Authentication failed Invalid CA chain from the cluster
2024-11-20 15:35:37,693Z ERROR athena_auth.py:179 Server encountered unexpected condition. Error: Traceback (most recent call last):
 'state': 'ERROR'}
2024-11-20 15:35:37,706Z ERROR auth.py:100 Traceback (most recent call last):
 'state': 'ERROR'}
2024-11-20 15:35:42,818Z ERROR athena_auth.py:272 Authentication failed Invalid CA chain from the cluster
2024-11-20 15:35:42,820Z ERROR athena_auth.py:179 Server encountered unexpected condition. Error: Traceback (most recent call last):
 'state': 'ERROR'}
2024-11-20 15:35:42,827Z ERROR auth.py:100 Traceback (most recent call last):
 'state': 'ERROR'}
2024-11-20 15:35:47,874Z ERROR athena_auth.py:272 Authentication failed Invalid CA chain from the cluster
2024-11-20 15:35:47,876Z ERROR athena_auth.py:179 Server encountered unexpected condition. Error: Traceback (most recent call last):
 'state': 'ERROR'}
2024-11-20 15:35:47,883Z ERROR auth.py:100 Traceback (most recent call last):
 'state': 'ERROR'}
2024-11-20 15:35:49,338Z ERROR athena_auth.py:272 Authentication failed Invalid CA chain from the cluster
2024-11-20 15:35:49,340Z ERROR athena_auth.py:179 Server encountered unexpected condition. Error: Traceback (most recent call last):
 'state': 'ERROR'}
2024-11-20 15:35:49,346Z ERROR auth.py:100 Traceback (most recent call last):
 'state': 'ERROR'}
2024-11-20 15:35:49,388Z ERROR athena_auth.py:272 Authentication failed Invalid CA chain from the cluster
2024-11-20 15:35:49,390Z ERROR athena_auth.py:179 Server encountered unexpected condition. Error: Traceback (most recent call last):
 'state': 'ERROR'}
2024-11-20 15:35:49,395Z ERROR auth.py:100 Traceback (most recent call last):
 'state': 'ERROR'}
2024-11-20 15:35:52,955Z ERROR athena_auth.py:272 Authentication failed Invalid CA chain from the cluster
2024-11-20 15:35:52,957Z ERROR athena_auth.py:179 Server encountered unexpected condition. Error: Traceback (most recent call last):
 'state': 'ERROR'}
2024-11-20 15:35:52,963Z ERROR auth.py:100 Traceback (most recent call last):
 'state': 'ERROR'}
2024-11-20 15:35:58,018Z ERROR athena_auth.py:272 Authentication failed Invalid CA chain from the cluster
2024-11-20 15:35:58,020Z ERROR athena_auth.py:179 Server encountered unexpected condition. Error: Traceback (most recent call last):
 'state': 'ERROR'}
2024-11-20 15:35:58,029Z ERROR auth.py:100 Traceback (most recent call last):
 'state': 'ERROR'}
2024-11-20 15:36:03,086Z ERROR athena_auth.py:272 Authentication failed Invalid CA chain from the cluster
2024-11-20 15:36:03,088Z ERROR athena_auth.py:179 Server encountered unexpected condition. Error: Traceback (most recent call last):
 'state': 'ERROR'}
2024-11-20 15:36:03,093Z ERROR auth.py:100 Traceback (most recent call last):
 'state': 'ERROR'}
2024-11-20 15:36:07,544Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/v4.0.a2/authn/directory-services after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-20 15:36:07,546Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-20 15:36:50,274Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/authz/v1/proxy after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-20 15:36:50,276Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-20 15:37:12,294Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/v4.0.a2/authn/directory-services after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-20 15:37:12,299Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-20 15:37:24,141Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/authz/v1/proxy after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-20 15:37:24,142Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-20 15:38:00,030Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/authz/v1/proxy after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-20 15:38:00,033Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-20 15:38:15,898Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/v4.0.a2/authn/directory-services after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-20 15:38:15,900Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-20 15:38:35,786Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/authz/v1/proxy after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-20 15:38:35,789Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-20 15:39:11,621Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/authz/v1/proxy after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-20 15:39:11,623Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-21 00:49:26,346Z ERROR service_jwt_tokens.py:39 IAM token validation failed with Signature verification failed
2024-11-21 00:50:08,831Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/v4.0.a2/authn/directory-services after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-21 00:50:08,833Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-21 00:51:13,518Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/v4.0.a2/authn/directory-services after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-21 00:51:13,520Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-21 00:52:19,358Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/v4.0.a2/authn/directory-services after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-21 00:52:19,360Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-21 00:53:23,265Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/v4.0.a2/authn/directory-services after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-21 00:53:23,266Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-21 00:54:26,788Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/v4.0.a2/authn/directory-services after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-21 00:54:26,791Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-21 00:55:29,607Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/v4.0.a2/authn/directory-services after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-21 00:55:29,609Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-21 00:56:32,988Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/v4.0.a2/authn/directory-services after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-21 00:56:32,990Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-21 00:57:36,120Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/v4.0.a2/authn/directory-services after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-21 00:57:36,122Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-21 00:58:39,547Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/v4.0.a2/authn/directory-services after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-21 00:58:39,549Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-21 00:59:42,244Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/v4.0.a2/authn/directory-services after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-21 00:59:42,246Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-21 01:00:47,729Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/v4.0.a2/authn/directory-services after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-21 01:00:47,732Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-21 01:01:52,427Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/v4.0.a2/authn/directory-services after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-21 01:01:52,429Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-21 01:02:58,797Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/v4.0.a2/authn/directory-services after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-21 01:02:58,800Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-21 01:04:01,906Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/v4.0.a2/authn/directory-services after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-21 01:04:01,908Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-21 01:04:26,244Z ERROR service_jwt_tokens.py:39 IAM token validation failed with Signature verification failed
2024-11-21 01:05:04,212Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/v4.0.a2/authn/directory-services after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-21 01:05:04,214Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-21 01:06:06,732Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/v4.0.a2/authn/directory-services after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-21 01:06:06,734Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-21 01:07:10,101Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/v4.0.a2/authn/directory-services after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-21 01:07:10,104Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-21 01:08:14,686Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/v4.0.a2/authn/directory-services after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-21 01:08:14,688Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-21 01:09:18,764Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/v4.0.a2/authn/directory-services after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-21 01:09:18,766Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-21 01:10:23,905Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/v4.0.a2/authn/directory-services after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-21 01:10:23,908Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-21 01:11:28,439Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/v4.0.a2/authn/directory-services after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-21 01:11:28,441Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-21 01:12:33,210Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/v4.0.a2/authn/directory-services after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-21 01:12:33,212Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-21 01:13:36,140Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/v4.0.a2/authn/directory-services after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-21 01:13:36,142Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-21 01:14:41,482Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/v4.0.a2/authn/directory-services after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-21 01:14:41,484Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-21 01:15:46,831Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/v4.0.a2/authn/directory-services after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-21 01:15:46,833Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-21 01:16:51,218Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/v4.0.a2/authn/directory-services after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-21 01:16:51,221Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-21 01:17:22,712Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/v4.0.a2/authn/saml-identity-providers after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-21 01:17:22,713Z ERROR identity_provider.py:450  iamv2 API failed with Failed to send request to IAMv2
2024-11-21 01:17:22,716Z ERROR resource.py:254  Traceback (most recent call last):
 'state': 'ERROR'}
2024-11-21 01:17:48,939Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/authz/v1/authorize after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-21 01:17:48,941Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-21 01:17:48,952Z ERROR entity.py:75  Expected JSON schema not found. Got key error ''status''
2024-11-21 01:17:53,457Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/v4.0.a2/authn/directory-services after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-21 01:17:53,459Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-21 01:18:55,472Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/v4.0.a2/authn/directory-services after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-21 01:18:55,474Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-21 01:19:13,968Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/authz/v1/authorize after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-21 01:19:13,970Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-21 01:19:13,980Z ERROR entity.py:75  Expected JSON schema not found. Got key error ''status''
2024-11-21 01:19:26,348Z ERROR service_jwt_tokens.py:39 IAM token validation failed with Signature verification failed
2024-11-21 01:19:58,630Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/v4.0.a2/authn/directory-services after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-21 01:19:58,632Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-21 01:21:02,434Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/v4.0.a2/authn/directory-services after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-21 01:21:02,436Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-21 01:22:07,898Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/v4.0.a2/authn/directory-services after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-21 01:22:07,900Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-21 01:23:12,435Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/v4.0.a2/authn/directory-services after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-21 01:23:12,437Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-21 01:24:14,895Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/v4.0.a2/authn/directory-services after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-21 01:24:14,897Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-21 01:24:49,493Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/authz/v1/authorize after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-21 01:24:49,495Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-21 01:24:49,504Z ERROR entity.py:75  Expected JSON schema not found. Got key error ''status''
2024-11-21 01:24:49,506Z ERROR shell.py:162  Traceback (most recent call last):
2024-11-21 01:25:17,016Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/v4.0.a2/authn/directory-services after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-21 01:25:17,018Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-21 01:26:21,239Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/v4.0.a2/authn/directory-services after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-21 01:26:21,240Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-21 01:27:26,078Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/v4.0.a2/authn/directory-services after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-21 01:27:26,081Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-21 01:28:30,555Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/v4.0.a2/authn/directory-services after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-21 01:28:30,557Z ERROR resource.py:263  Traceback (most recent call last):
2024-11-21 01:29:35,823Z ERROR client_util.py:162  Failed to complete request to https://iam-proxy.ntnx-base:8445/api/iam/v4.0.a2/authn/directory-services after 5 tries. Error: <urlopen error [Errno -2] Name or service not known>
2024-11-21 01:29:35,825Z ERROR resource.py:263  Traceback (most recent call last):
  • 15 replies
  • November 21, 2024
④nslookup iam-proxy.ntnx-base
Server:        127.0.0.1
Address:    127.0.0.1#53
** server can't find iam-proxy.ntnx-base: NXDOMAIN
⑤mspctl cluster health
COMPONENT          HEALTHY    DESCRIPTION
Core               true       Core is healthy
Addons             false      Addons is unhealthy
Extensions         false      Extensions is unhealthy
Node               false      Node is unhealthy
LB                 true       LB is healthy
ClusterWorkflow    true       ClusterWorkflow is healthy
  • 15 replies
  • November 21, 2024
⑦docker plugin ls
ID                  NAME                DESCRIPTION         ENABLED
  • 15 replies
  • November 21, 2024
⑥sudo kubectl get pods -A
NAMESPACE           NAME                                                    READY   STATUS      RESTARTS   AGE
default             anc-hermes-7f44c7954c-xk5t8                             1/1     Running     0          2d19h
default             anc-mysql-0                                             2/2     Running     0          2d19h
default             anc-ovn-0                                               2/2     Running     0          2d19h
default             anc-policydb-0                                          1/1     Running     0          2d19h
kube-system         cloud-controller-manager-glcmw                          1/1     Running     0          2d19h
kube-system         coredns-5974f559c5-nfxc4                                1/1     Running     0          2d19h
kube-system         kube-apiserver-ntnx-192-168-0-110-a-pcvm                3/3     Running     0          2d19h
kube-system         kube-flannel-ds-29hns                                   1/1     Running     0          2d19h
kube-system         kube-proxy-ds-h4g55                                     1/1     Running     0          2d19h
kube-system         lb-controller-deployment-0                              1/1     Running     0          2d19h
kube-system         mspdns-7rsqr                                            1/1     Running     0          2d19h
kube-system         mspserviceregistry-7856f6bd69-t6prc                     1/1     Running     0          2d19h
  • 15 replies
  • November 21, 2024
post the result below.
https://liberation-of-se-like-slaves.net/sudo-kubectl-get-pods-a/
  • 15 replies
  • November 22, 2024
  • November 25, 2024
困っていたので参考にします
