Install Nutanix CE on DL380 Gen10 | Nutanix Community
  • October 30, 2024
  • 258 views
we are evaluating Nutanix for our datacenter deployment, and were thinking to install CE on one of our older DL360 Gen10 servers that we have here, just to see the interface, UI etc.
However, I am completely failing to install it. Neither USB (tried Rufus with GPT and MBR, as well as unetbootin) nor mounted ISO via ILO are being recognized. I tested with Proxmox ISO, and it loaded instantly via ILO/ISO.
Any recommendations on what to check or what might be causing the issue?
ktelep
  • 541 replies
  • October 30, 2024
What error do you get when trying to boot the CE installer?  Does it boot at all and get into the installer and fail?   Does it just not find the installer at all?   Have you tried redownloading the ISO?
HunterLAFR
  • 20 replies
  • October 31, 2024
It looks like a corrupted iso.
try re-downloading it, as @ktelep said,
and maybe give it a try in a vm to check that boots fine, just to have more information.
BTW, are you doing this with the latest version of CE?
https://next.nutanix.com/discussion-forum-14/download-community-edition-38417
cheers.
if it is not booting, as suggested download it again.there could be something wrong with the ISO iteself.try to confirm the downloaded file is healthy using checksum.
  • Trendsetter
  • 40 replies
  • October 31, 2024
I would bet it’s the UEFI settings in the BIOS.  Make sure UEFI is enabled for boot devices and that you’re using the UEFI devices.
  • 1367 replies
  • November 1, 2024
Make sure you boot with usb stick and make the usb stick with rufus in windows. Then in rufus make sure you select the corresponding setup of you hp server.
HP server boots in uefi? Make the usb stick GPT.
HP server boots in BIOS? Make the usb stick MBT.
