Nutanix supports an Prism Central upgrade path from current version N to target N+2 in most cases. | Nutanix Community
  • September 7, 2024
  • 612 views
Hi there
We are running pc.2023.4.0.2 and because we would like to upgrade to AOS 6.8.1, we need to first upgrade the Prism Central to pc.2024.x. However, upgrading from pc.2023.4.0.2 to any pc.2024.x at the moment, it’s not supported. As of today, the latest PC Version is 2024.1.0.2.
I do understand the upgrade N to N+2, but when it comes to PC, i don’t know what N+2 means relative to pc.2023.4.0.2.
Considering that AOS 6.5 is going EOM in Oct 2024, we are a little afraid that we’ll not be able to upgrade our AOS’es 6.5.x to AOS 6.8 in time, because PC 2024.x is a prerequisite for AOS 6.8.
What to expect here, and how to proceed?
Best regards,
Casian
DylanH
  • Trendsetter
  • 46 replies
  • October 5, 2024
Hello, not sure to understand exactly what you want to do. But I will try to reply and do no hesitation to said me if you want more details.
you are not able to upgrade with on click pc2023 to 2024 big it’s big new release. You must to destroyed, unregistered your clusters, rebuild, and register your cluster.
next, 2024.1.0.2 is a pc version which is compatible with your AOS version 6.5.x
maybe I replied to late.
regards
  • 8 replies
  • October 7, 2024
Hi there.
I’ve sort of solved it with support. Seeing no answers for after a few days, i’ve decided to ask support. They told me that indeed Upgrade from pc.2023.4.0.2 to any pc.2024.1.x was not possible, but in less than one week the 2024.2 should be released and I will finally be able to upgrade to 2024. versions. That was indeed the case and we upgraded the PC.
I still didn’t get an answer how to understand N+2 on PC versioning, but ultimately i’ve been able to upgrade to 2024.2 and for me it’s solved.
Best regards
Casian
DylanH
  • Trendsetter
  • 46 replies
  • October 7, 2024
Perfect, happy for you.
Dylan
