Setting up Nutanix CE2 failing 2404/2430 | Nutanix Community
Title was of course 2402/2430, not 2404/2430 🙃
Having an issue in my home lab…
The issue at hand
I had Nutanix CE2 running on this machine for more than a month. However, due to odd crashes and false positives with disconnect issues on the vs0 configuration (I guess), I figured I would attempt a complete reinstall, having used DP to backup all VMs to another Nutanix CE2 setup. I believe I made a configuration error at some point.
However, re-installing with all the exact same devices and settings, I’m faced with this:
InstallerVM timeout occurred, current retry 0
Please take a look at installer_vm_*.log inside foundation logs to debug hypervisor installation issues
After which it will restart the process.
I’ve found somewhere near 2 other examples of this, stopping at the same progress [2402/2430], but I can’t figure out the solution.
Maybe someone can tell me how to actually find that installer_vm_*.log, as I couldn’t find it anywhere.
The Setup
Motherboard: MSI B550M PRO-VHD
CPU: AMD Ryzen 9 5900X
Memory: 128GB Corsair Vengeance LPX DDR4 3200Mhz
Disks:
Kingston KC3000 M.2 2280 NVMe SSD 1TB Data
Toshiba HDD 3TB Data
Samsung SSD 830 (256GB) CVM
Kingston DataTraveler Exodia M 64GB Hypervisor
I did notice that the DataTraveler shows up as DataTraveler 3.0 during the setup, while it’s a 3.2 Gen1.
Additional context
As said, having had it run for more than a month I thought I wouldn’t run into this issue, however I did have this the first time I installed it, but I can’t remember the solution, neither can my notes.
All my links on Google have turned purple and I’m out of clues.
What have I tried
  • Disabling secure boot in BIOS (Mentioned it has to be off for Foundation)
  • Replacing the USB installation media (Phoenix)
  • Replacing the USB media for the Hypervisor
  • XHCI Hand-off (Disabled and enabled) -- Desperate
  • Tried all the various USB port combinations
  • Waited patiently for decades while the installation fails a few times
  • Lastly, having it running overnight it did finish with caveat, didn’t reach 2430/2430 but said to remove installation media and reboot, which I did, but no CVM was listed running virsh list --all
Hoping for any point or direction at this point.
Thanks in advance!
Best answer by Oreax
Appears this got me to the next level, thanks over on Reddit! https://www.reddit.com/r/nutanix/comments/1drxkr5/
1. Once the device is booting up, press CTRL + C to get a terminal.
2. Open /root/phoenix/imaging_helper/installer_vm.py
3. Scroll down to around lines 31-36 where it says:
HYP_INSTALL_TIMEOUT = dict(
esx=15 * 2 * 60,
hyperv=15 * 2 *60,
kvm=20 * 2 * 60,
xen= 10 * 2 * 60)
HYP_INSTALL_TIMEOUT_MAX = 30 * 60
increase these values, I went all the way doubling it so the timeout will not happen too quickly.
4. Run this: ./ce_installer && screen -r
  • 8 replies
  • June 30, 2024
Of course I found the installer.log right after sending this post :)
cat installer.log
2024-06-30 09:50:45,933 INFO  Scanning devices to assemble RAID. This may take few minutes
2024-06-30 09:50:45,933 INFO  Scanning devices: ['sda', 'nvme0n1']
2024-06-30 09:50:46,215 DEBUG  ret: 0, out: , error:
2024-06-30 09:50:46,342 INFO  Model detected: CommunityEdition
2024-06-30 09:50:48,456 INFO  vpd_info {'rackable_unit_serial': u'To be filled by O.E.M.', 'vpd_method': None, 'node_serial': u'To be filled by O.E.M.'}
2024-06-30 09:50:48,457 INFO  Using block_id from FRU
2024-06-30 09:50:48,457 INFO  Generating cluster_id
2024-06-30 09:50:48,457 INFO  node_serial = b5c06e24-d840-458e-83b2-f293c6347322, node_uuid = 6bb465e3-5fdd-4739-8fdc-d133ffd10006, block_id = To be filled by O.E.M., cluster_id = 6370579458114300578, model = USE_LAYOUT, model_string = CommunityEdition, node_position =
2024-06-30 09:50:48,817 INFO  Re-reading partition table for sdb
2024-06-30 09:50:49,381 INFO  LVM volume group ahv was not detected; assuming that AHV is installed on normal partitions
2024-06-30 09:50:49,511 INFO  LVM volume group ahv was not detected; assuming that AHV is installed on normal partitions
2024-06-30 09:51:23,664 INFO  Getting NOS version from the CVM
2024-06-30 09:51:23,781 DEBUG  Marker file found, skipping assembling RAID again
2024-06-30 09:51:24,155 DEBUG  Couldn't find AOS release version on the disks
2024-06-30 09:51:24,223 INFO  Getting AOS version from /mnt/iso/images/svm/nutanix_installer_package.tar.p00, This may take a few minutes if phoenix is running from BMC
2024-06-30 09:52:44,838 INFO  Getting AOS version from /mnt/iso/images/svm/nutanix_installer_package.tar.p00, This may take a few minutes if phoenix is running from BMC
2024-06-30 09:52:45,713 INFO  Getting AOS version from /mnt/iso/images/svm/nutanix_installer_package.tar.p00, This may take a few minutes if phoenix is running from BMC
2024-06-30 09:52:46,656 INFO  Phoenix ISO is already mounted
2024-06-30 09:53:07,216 INFO  Picking the bundled hypervisor:/mnt/svm_installer/./install/ahv/kvm_host_bundle_20220304.342.iso
2024-06-30 09:53:07,437 INFO  Getting AOS version from /mnt/iso/images/svm/nutanix_installer_package.tar.p00, This may take a few minutes if phoenix is running from BMC
2024-06-30 09:54:47,868 INFO  Getting AOS version from /mnt/iso/images/svm/nutanix_installer_package.tar.p00, This may take a few minutes if phoenix is running from BMC
2024-06-30 09:54:48,728 INFO  Getting AOS version from /mnt/iso/images/svm/nutanix_installer_package.tar.p00, This may take a few minutes if phoenix is running from BMC
2024-06-30 09:54:49,567 INFO  Getting AOS version from /mnt/iso/images/svm/nutanix_installer_package.tar.p00, This may take a few minutes if phoenix is running from BMC
2024-06-30 09:54:50,422 INFO  Getting AOS version from /mnt/iso/images/svm/nutanix_installer_package.tar.p00, This may take a few minutes if phoenix is running from BMC
2024-06-30 09:54:58,345 INFO  Phoenix ISO is already mounted
2024-06-30 09:55:18,855 INFO  Picking the bundled hypervisor:/mnt/svm_installer/./install/ahv/kvm_host_bundle_20220304.342.iso
2024-06-30 09:55:18,952 INFO  Phoenix ISO is already mounted
2024-06-30 09:55:38,838 INFO  Picking the bundled hypervisor:/mnt/svm_installer/./install/ahv/kvm_host_bundle_20220304.342.iso
2024-06-30 09:55:47,316 DEBUG  Available memory 125.743518829, Max allowed memory for CVM: 119.743518829
2024-06-30 09:55:47,316 DEBUG  Using new CVM sizing policy: False
2024-06-30 09:55:47,316 DEBUG  Determining numa node for allocating vcpu
2024-06-30 09:55:47,316 DEBUG  Determining numa node for storage controller:
2024-06-30 09:55:47,318 ERROR  Couldn't determine numa_node for device,  exception: StandardError(u"Failed command: [lspci -d  -nm] with error: [lspci: -d: ':' expected]\nout: []",)
2024-06-30 09:55:47,318 DEBUG  Couldn't determine numa node for storage controller
2024-06-30 09:55:47,318 DEBUG  Couldn't identify a numa node, falling back to 0
2024-06-30 09:55:47,335 DEBUG  Computed CVM size to be vcpu 6, mem 20
2024-06-30 09:55:47,335 DEBUG  Enabling numa because sufficient memory and CPUs available on a numa node 0
2024-06-30 09:55:47,345 INFO  Running CVM Installer
2024-06-30 09:55:47,345 INFO  Generating unique SSH identity for this Hypervisor-CVM pair.
2024-06-30 09:55:47,379 INFO  Generating SSL certificate for this Hypervisor-CVM pair.
2024-06-30 09:55:47,383 INFO  Extracting the SVM installer into memory. This will take some time...
2024-06-30 09:56:02,780 INFO  Injecting SSH keys into SVM installer.
2024-06-30 09:56:02,780 INFO  Checking if a newer HCL exists on CVM
2024-06-30 09:56:02,780 INFO  Getting NOS version from the CVM
2024-06-30 09:56:02,924 DEBUG  Marker file found, skipping assembling RAID again
2024-06-30 09:56:03,302 INFO  Using hcl from /phoenix/hcl.json with last_edit 1675751144
2024-06-30 09:56:03,416 INFO  Drive 'SAMSUNG SSD 830' added to hcl /phoenix/hcl.json
2024-06-30 09:56:03,444 INFO  Drive 'SAMSUNG SSD 830' added to hcl /mnt/svm_installer/install/config/hcl.json
2024-06-30 09:56:03,471 INFO  Drive 'SAMSUNG SSD 830' is already present in hcl /phoenix/hcl.json
2024-06-30 09:56:03,475 INFO  Drive 'SAMSUNG SSD 830' is already present in hcl /mnt/svm_installer/install/config/hcl.json
2024-06-30 09:56:03,479 INFO  Drive 'KINGSTON SKC3000S1024G' added to hcl /phoenix/hcl.json
2024-06-30 09:56:03,507 INFO  Drive 'KINGSTON SKC3000S1024G' added to hcl /mnt/svm_installer/install/config/hcl.json
2024-06-30 09:56:03,534 INFO  Drive 'KINGSTON SKC3000' added to hcl /phoenix/hcl.json
2024-06-30 09:56:03,562 INFO  Drive 'KINGSTON SKC3000' added to hcl /mnt/svm_installer/install/config/hcl.json
2024-06-30 09:56:03,714 INFO  Host boot_disk: sdb
2024-06-30 09:56:03,714 INFO  Imaging the SVM
2024-06-30 09:56:03,715 INFO  Formatting 3 data disks ['sda', 'nvme0n1', 'sdc']
2024-06-30 09:56:03,715 INFO  Deactivating LVM VG ahv
2024-06-30 09:56:03,752 INFO  Zeroing the superblock: []
2024-06-30 09:56:03,911 INFO  AHV LVM VG was not found
2024-06-30 09:56:03,911 INFO  Calling wipefs on /dev/sdb
2024-06-30 09:56:03,936 INFO  Executing ['python2.7', '/mnt/svm_installer/install/bin/svm_rescue'] with arg_list ['-i', '/mnt/svm_installer/install', '--factory_deploy', '--node_name=8603595a-A', '--node_serial=b5c06e24-d840-458e-83b2-f293c6347322', '--node_model=USE_LAYOUT', '--cluster_id=6370579458114300578', '--node_uuid=6bb465e3-5fdd-4739-8fdc-d133ffd10006']
2024-06-30 09:56:04,487 DEBUG  This AHV supports metadata-iso
2024-06-30 09:56:04,532 INFO  Installer VM memory = 32G
2024-06-30 09:56:04,532 INFO  Installation Device = /dev/sdb
2024-06-30 09:56:04,533 DEBUG  Using AHV-metadata iso for AHV installation
2024-06-30 09:56:04,533 INFO  Executing /usr/bin/qemu-system-x86_64 -m 32G -machine q35 -enable-kvm -drive file=/dev/sdb,cache=writethrough,format=raw -drive file=/phoenix/imaging_helper/installer.iso,media=cdrom -netdev user,id=net0,net=192.168.5.0/24 -device e1000,netdev=net0,id=net0,mac=d8:43:ae:4d:aa:a2 -vnc :1 -boot order=d -pidfile installer_vm.pid -daemonize -smp 4 -serial file:/tmp/installer_vm.log -drive file=/phoenix/imaging_helper/installer.iso-meta.iso,media=cdrom -drive file=/usr/share/edk2.git/ovmf-x64/OVMF_CODE-pure-efi.fd,if=pflash,format=raw,unit=0,readonly=on -drive file=/usr/share/edk2.git/ovmf-x64/OVMF_VARS-pure-efi.fd,if=pflash,format=raw,unit=1
2024-06-30 09:56:04,564 INFO  Installer VM is now running the installation
2024-06-30 09:56:04,564 INFO  Installer VM running with PID = 2603
2024-06-30 09:56:34,595 INFO  Loaded config parameters successfully
2024-06-30 09:56:34,595 INFO  [30/2430] Hypervisor installation in progress
2024-06-30 09:57:04,625 INFO  [60/2430] Hypervisor installation in progress
2024-06-30 09:57:34,655 INFO  [90/2430] Hypervisor installation in progress
2024-06-30 09:58:04,686 INFO  [120/2430] Hypervisor installation in progress
2024-06-30 09:58:34,700 INFO  [150/2430] Hypervisor installation in progress
2024-06-30 09:58:47,792 DEBUG  svm_rescue:
Unable to read /etc/nutanix/release_version: [Errno 2] No such file or directory: '/etc/nutanix/release_version'
2024-06-30 09:56:04,499Z INFO svm_rescue:928 Will image ['/dev/sda'] from /mnt/svm_installer/install/images/svm.tar.xz.
2024-06-30 09:56:04,499Z INFO svm_rescue:114 exec_cmd: mdadm --stop --scan
2024-06-30 09:56:04,501Z INFO svm_rescue:713 Disks detected from Phoenix: ['/dev/sda', '/dev/nvme0n1', '/dev/sdc']
2024-06-30 09:56:04,501Z INFO svm_rescue:735 Available disk /dev/sda
2024-06-30 09:56:04,501Z INFO svm_rescue:738 Repartitioning disk /dev/sda
2024-06-30 09:56:04,501Z INFO svm_rescue:114 exec_cmd: parted -s /dev/sda unit s print
2024-06-30 09:56:04,511Z INFO svm_rescue:187 No partition table present on disk /dev/sda
2024-06-30 09:56:04,512Z INFO svm_rescue:675 Need to repartition and format blank boot drive /dev/sda
2024-06-30 09:56:04,512Z INFO svm_rescue:114 exec_cmd: /mnt/cdrom/bin/repartition_disks -b /dev/sda
2024-06-30 09:56:05,417Z INFO svm_rescue:685 ret: 0
2024-06-30 09:56:05,417Z INFO svm_rescue:686 stdout:
2024-06-30 09:56:05,417Z INFO svm_rescue:687 stderr: Unable to read /etc/nutanix/release_version: [Errno 2] No such file or directory: '/etc/nutanix/release_version'
2024-06-30 09:56:05,091Z INFO repartition_disks:367 Cleaning existing partition tables on disks: set(['/dev/sda'])
2024-06-30 09:56:05,104Z INFO repartition_disks:378 Creating boot partitions on disks: set(['/dev/sda'])
2024-06-30 09:56:05,105Z INFO repartition_disks:291 Disk /dev/sda: size 238 GB
2024-06-30 09:56:05,118Z INFO repartition_disks:215 Detected partition /dev/sda1
2024-06-30 09:56:05,118Z INFO repartition_disks:322 Disk /dev/sda size 238 GB
2024-06-30 09:56:05,143Z INFO repartition_disks:215 Detected partition /dev/sda2
2024-06-30 09:56:05,143Z INFO repartition_disks:322 Disk /dev/sda size 238 GB
2024-06-30 09:56:05,299Z INFO repartition_disks:215 Detected partition /dev/sda3
2024-06-30 09:56:05,299Z INFO repartition_disks:322 Disk /dev/sda size 238 GB
2024-06-30 09:56:05,378Z INFO repartition_disks:215 Detected partition /dev/sda4
2024-06-30 09:56:05,417Z INFO svm_rescue:735 Available disk /dev/nvme0n1
2024-06-30 09:56:05,417Z INFO svm_rescue:114 exec_cmd: /mnt/cdrom/bin/repartition_disks -d /dev/nvme0n1
2024-06-30 09:56:07,102Z INFO svm_rescue:735 Available disk /dev/sdc
2024-06-30 09:56:07,102Z INFO svm_rescue:114 exec_cmd: /mnt/cdrom/bin/repartition_disks -d /dev/sdc
2024-06-30 09:56:08,917Z INFO svm_rescue:654 Running blkdiscard on disk /dev/sda4
2024-06-30 09:56:08,917Z INFO svm_rescue:654 Running blkdiscard on disk /dev/nvme0n1p1
2024-06-30 09:56:08,917Z INFO svm_rescue:654 Running blkdiscard on disk /dev/sdc1
2024-06-30 09:56:08,917Z INFO svm_rescue:659 Formatting disks ['/dev/nvme0n1p1', '/dev/sda4', '/dev/sdc1']
2024-06-30 09:56:08,917Z INFO svm_rescue:114 exec_cmd: /mnt/cdrom/bin/clean_disks -p /dev/nvme0n1p1,/dev/sda4,/dev/sdc1
2024-06-30 09:56:18,917Z INFO svm_rescue:848 All partitions in boot disk /dev/sda: ['/dev/sda4', '/dev/sda3', '/dev/sda2', '/dev/sda1']
2024-06-30 09:56:18,917Z INFO svm_rescue:837 Boot partitions: ['/dev/sda3', '/dev/sda2', '/dev/sda1']
2024-06-30 09:56:18,917Z INFO svm_rescue:850 Boot partitions for boot disk /dev/sda: [['/dev/sda1', '/dev/sda2', '/dev/sda3']]
2024-06-30 09:56:18,917Z INFO svm_rescue:654 Running blkdiscard on disk /dev/sda1
2024-06-30 09:56:18,917Z INFO svm_rescue:654 Running blkdiscard on disk /dev/sda2
2024-06-30 09:56:18,917Z INFO svm_rescue:654 Running blkdiscard on disk /dev/sda3
2024-06-30 09:56:18,917Z INFO svm_rescue:659 Formatting disks ['/dev/sda1', '/dev/sda2', '/dev/sda3']
2024-06-30 09:56:18,917Z INFO svm_rescue:114 exec_cmd: /mnt/cdrom/bin/clean_disks -p /dev/sda1,/dev/sda2,/dev/sda3
2024-06-30 09:56:22,826Z INFO svm_rescue:114 exec_cmd: mount /dev/sda1 /mnt/disk
2024-06-30 09:56:23,054Z INFO svm_rescue:114 exec_cmd: cd /mnt/disk; tar -xJpf /mnt/svm_installer/install/images/svm.tar.xz
2024-06-30 09:56:38,137Z INFO svm_rescue:114 exec_cmd: bash -c 'cd /mnt/disk/usr/local/nutanix; tar -xf /mnt/svm_installer/install/pkg/nutanix-bootstrap-el7.3-release-fraser-6.5.2-stable-f2ce4db7d67f495ebfd6208bef9ab0afec9c74af.tar.xz'
2024-06-30 09:56:39,143Z INFO svm_rescue:902 hardlink all duplicate files: cd /mnt/disk/usr/local/nutanix;hardlink -c -v .
2024-06-30 09:56:39,143Z INFO svm_rescue:114 exec_cmd: bash -c 'cd /mnt/disk/usr/local/nutanix;hardlink -c -v .'
2024-06-30 09:56:39,146Z INFO svm_rescue:908 hardlink output:
Directories 15
Objects 98
IFREG 82
Comparisons 0
Linked 0
saved 0
2024-06-30 09:56:39,147Z INFO svm_rescue:114 exec_cmd: bash -c 'cd /mnt/disk/usr/local/nutanix; tar -xf /mnt/svm_installer/install/pkg/nutanix-core-el7.3-release-fraser-6.5.2-stable-f2ce4db7d67f495ebfd6208bef9ab0afec9c74af.tar.xz'
2024-06-30 09:56:58,483Z INFO svm_rescue:902 hardlink all duplicate files: cd /mnt/disk/usr/local/nutanix;hardlink -c -v .
2024-06-30 09:56:58,483Z INFO svm_rescue:114 exec_cmd: bash -c 'cd /mnt/disk/usr/local/nutanix;hardlink -c -v .'
2024-06-30 09:56:58,547Z INFO svm_rescue:908 hardlink output:
Directories 125
Objects 2717
IFREG 2514
Comparisons 639
Linked 634
saved 174661632
2024-06-30 09:56:58,547Z INFO svm_rescue:114 exec_cmd: bash -c 'cd /mnt/disk/usr/local/nutanix; tar -xf /mnt/svm_installer/install/pkg/nutanix-clusters-el7.3-release-fraser-6.5.2-stable-f2ce4db7d67f495ebfd6208bef9ab0afec9c74af.tar.gz'
2024-06-30 09:56:58,552Z INFO svm_rescue:902 hardlink all duplicate files: cd /mnt/disk/usr/local/nutanix;hardlink -c -v .
2024-06-30 09:56:58,552Z INFO svm_rescue:114 exec_cmd: bash -c 'cd /mnt/disk/usr/local/nutanix;hardlink -c -v .'
2024-06-30 09:56:58,564Z INFO svm_rescue:908 hardlink output:
Directories 126
Objects 2721
IFREG 2517
Comparisons 5
Linked 0
saved 0
2024-06-30 09:56:58,565Z INFO svm_rescue:114 exec_cmd: bash -c 'cd /mnt/disk/usr/local/nutanix; tar -xf /mnt/svm_installer/install/pkg/nutanix-pe-el7.3-release-fraser-6.5.2-stable-f2ce4db7d67f495ebfd6208bef9ab0afec9c74af.tar.xz'
2024-06-30 09:56:59,994Z INFO svm_rescue:902 hardlink all duplicate files: cd /mnt/disk/usr/local/nutanix;hardlink -c -v .
2024-06-30 09:56:59,994Z INFO svm_rescue:114 exec_cmd: bash -c 'cd /mnt/disk/usr/local/nutanix;hardlink -c -v .'
2024-06-30 09:57:00,050Z INFO svm_rescue:908 hardlink output:
Directories 339
Objects 4659
IFREG 4240
Comparisons 408
Linked 394
saved 96567296
2024-06-30 09:57:00,051Z INFO svm_rescue:114 exec_cmd: bash -c 'cd /mnt/disk/usr/local/nutanix; tar -xf /mnt/svm_installer/install/pkg/nutanix-diagnostics-el7.3-release-fraser-6.5.2-stable-f2ce4db7d67f495ebfd6208bef9ab0afec9c74af.tar.xz'
2024-06-30 09:57:00,704Z INFO svm_rescue:902 hardlink all duplicate files: cd /mnt/disk/usr/local/nutanix;hardlink -c -v .
2024-06-30 09:57:00,704Z INFO svm_rescue:114 exec_cmd: bash -c 'cd /mnt/disk/usr/local/nutanix;hardlink -c -v .'
2024-06-30 09:57:00,742Z INFO svm_rescue:908 hardlink output:
Directories 345
Objects 4756
IFREG 4331
Comparisons 140
Linked 127
saved 75358208
2024-06-30 09:57:00,743Z INFO svm_rescue:114 exec_cmd: bash -c 'cd /mnt/disk/usr/local/nutanix; tar -xf /mnt/svm_installer/install/pkg/nutanix-infrastructure-el7.3-release-fraser-6.5.2-stable-f2ce4db7d67f495ebfd6208bef9ab0afec9c74af.tar.xz'
2024-06-30 09:57:02,566Z INFO svm_rescue:902 hardlink all duplicate files: cd /mnt/disk/usr/local/nutanix;hardlink -c -v .
2024-06-30 09:57:02,566Z INFO svm_rescue:114 exec_cmd: bash -c 'cd /mnt/disk/usr/local/nutanix;hardlink -c -v .'
2024-06-30 09:57:02,617Z INFO svm_rescue:908 hardlink output:
Directories 371
Objects 5264
IFREG 4802
Comparisons 175
Linked 162
saved 52527104
2024-06-30 09:57:02,617Z INFO svm_rescue:114 exec_cmd: bash -c 'cd /mnt/disk/usr/local/nutanix; tar -xf /mnt/svm_installer/install/pkg/nutanix-lcm-2.5.0.2.32663.tar.xz'
2024-06-30 09:57:02,982Z INFO svm_rescue:902 hardlink all duplicate files: cd /mnt/disk/usr/local/nutanix;hardlink -c -v .
2024-06-30 09:57:02,982Z INFO svm_rescue:114 exec_cmd: bash -c 'cd /mnt/disk/usr/local/nutanix;hardlink -c -v .'
2024-06-30 09:57:03,003Z INFO svm_rescue:908 hardlink output:
Directories 392
Objects 5390
IFREG 4907
Comparisons 34
Linked 21
saved 499712
2024-06-30 09:57:03,004Z INFO svm_rescue:114 exec_cmd: bash -c 'cd /mnt/disk/usr/local/nutanix; tar -xf /mnt/svm_installer/install/pkg/nutanix-ikatproxy-master.tar.xz'
2024-06-30 09:57:03,619Z INFO svm_rescue:902 hardlink all duplicate files: cd /mnt/disk/usr/local/nutanix;hardlink -c -v .
2024-06-30 09:57:03,619Z INFO svm_rescue:114 exec_cmd: bash -c 'cd /mnt/disk/usr/local/nutanix;hardlink -c -v .'
2024-06-30 09:57:03,635Z INFO svm_rescue:908 hardlink output:
Directories 395
Objects 5396
IFREG 4910
Comparisons 13
Linked 0
saved 0
2024-06-30 09:57:03,636Z INFO svm_rescue:114 exec_cmd: bash -c 'cd /mnt/disk/usr/local/nutanix; tar -xf /mnt/svm_installer/install/pkg/nutanix-ikatcontrolplane-master.tar.xz'
2024-06-30 09:57:04,030Z INFO svm_rescue:902 hardlink all duplicate files: cd /mnt/disk/usr/local/nutanix;hardlink -c -v .
2024-06-30 09:57:04,031Z INFO svm_rescue:114 exec_cmd: bash -c 'cd /mnt/disk/usr/local/nutanix;hardlink -c -v .'
2024-06-30 09:57:04,046Z INFO svm_rescue:908 hardlink output:
Directories 398
Objects 5405
IFREG 4916
Comparisons 13
Linked 0
saved 0
2024-06-30 09:57:04,047Z INFO svm_rescue:114 exec_cmd: bash -c 'cd /mnt/disk/usr/local/nutanix; tar -xf /mnt/svm_installer/install/pkg/nutanix-networkservice-1.0.136.tar.xz'
2024-06-30 09:57:04,582Z INFO svm_rescue:902 hardlink all duplicate files: cd /mnt/disk/usr/local/nutanix;hardlink -c -v .
2024-06-30 09:57:04,582Z INFO svm_rescue:114 exec_cmd: bash -c 'cd /mnt/disk/usr/local/nutanix;hardlink -c -v .'
2024-06-30 09:57:04,602Z INFO svm_rescue:908 hardlink output:
Directories 401
Objects 5410
IFREG 4918
Comparisons 13
Linked 0
saved 0
2024-06-30 09:57:04,603Z INFO svm_rescue:114 exec_cmd: bash -c 'cd /mnt/disk/usr/local/nutanix; tar -xf /mnt/svm_installer/install/pkg/nutanix-serviceability-el7.3-release-fraser-6.5.2-stable-f2ce4db7d67f495ebfd6208bef9ab0afec9c74af.tar.xz'
2024-06-30 09:57:05,915Z INFO svm_rescue:902 hardlink all duplicate files: cd /mnt/disk/usr/local/nutanix;hardlink -c -v .
2024-06-30 09:57:05,915Z INFO svm_rescue:114 exec_cmd: bash -c 'cd /mnt/disk/usr/local/nutanix;hardlink -c -v .'
2024-06-30 09:57:05,954Z INFO svm_rescue:908 hardlink output:
Directories 529
Objects 6347
IFREG 5723
Comparisons 662
Linked 647
saved 50388992
2024-06-30 09:57:05,955Z INFO svm_rescue:114 exec_cmd: bash -c 'cd /mnt/disk/usr/local/nutanix; tar -xf /mnt/svm_installer/install/pkg/nutanix-ncc-el7.3-release-ncc-4.6.2.1-x86_64-latest.tar.gz'
2024-06-30 09:57:08,362Z INFO svm_rescue:902 hardlink all duplicate files: cd /mnt/disk/usr/local/nutanix;hardlink -c -v .
2024-06-30 09:57:08,362Z INFO svm_rescue:114 exec_cmd: bash -c 'cd /mnt/disk/usr/local/nutanix;hardlink -c -v .'
2024-06-30 09:57:08,407Z INFO svm_rescue:908 hardlink output:
Directories 756
Objects 7572
IFREG 6717
Comparisons 65
Linked 51
saved 44707840
2024-06-30 09:57:08,408Z INFO svm_rescue:114 exec_cmd: bash -c 'cd /mnt/disk/usr/local/nutanix; tar -xf /mnt/svm_installer/install/pkg/nutanix-minervacvm-el7.3-release-fsm-1.5.2-stable-5769c7bec5a02f5101db0a0a780d03a99b36e59b-x86_64.tar.gz'
2024-06-30 09:57:08,705Z INFO svm_rescue:902 hardlink all duplicate files: cd /mnt/disk/usr/local/nutanix;hardlink -c -v .
2024-06-30 09:57:08,705Z INFO svm_rescue:114 exec_cmd: bash -c 'cd /mnt/disk/usr/local/nutanix;hardlink -c -v .'
2024-06-30 09:57:08,751Z INFO svm_rescue:908 hardlink output:
Directories 967
Objects 9006
IFREG 7940
Comparisons 620
Linked 589
saved 18214912
2024-06-30 09:57:08,752Z INFO svm_rescue:114 exec_cmd: bash -c 'cd /mnt/disk/usr/local/nutanix; tar -xf /mnt/svm_installer/install/pkg/nutanix-perftools-el7.3-release-fraser-6.5.2-stable-f2ce4db7d67f495ebfd6208bef9ab0afec9c74af.tar.xz'
2024-06-30 09:57:09,454Z INFO svm_rescue:902 hardlink all duplicate files: cd /mnt/disk/usr/local/nutanix;hardlink -c -v .
2024-06-30 09:57:09,454Z INFO svm_rescue:114 exec_cmd: bash -c 'cd /mnt/disk/usr/local/nutanix;hardlink -c -v .'
2024-06-30 09:57:09,496Z INFO svm_rescue:908 hardlink output:
Directories 971
Objects 9055
IFREG 7985
Comparisons 58
Linked 39
saved 27410432
2024-06-30 09:57:09,497Z INFO svm_rescue:114 exec_cmd: bash -c 'cd /mnt/disk/srv/; tar -xf /mnt/svm_installer/install/pkg/nutanix-salt-el7.3-release-fraser-6.5.2-stable-f2ce4db7d67f495ebfd6208bef9ab0afec9c74af.tar.xz'
2024-06-30 09:57:09,504Z INFO svm_rescue:902 hardlink all duplicate files: cd /mnt/disk/srv/;hardlink -c -v .
2024-06-30 09:57:09,504Z INFO svm_rescue:114 exec_cmd: bash -c 'cd /mnt/disk/srv/;hardlink -c -v .'
2024-06-30 09:57:09,508Z INFO svm_rescue:908 hardlink output:
Directories 25
Objects 140
IFREG 115
Comparisons 0
Linked 0
saved 0
2024-06-30 09:57:09,509Z INFO svm_rescue:114 exec_cmd: bash -c 'cd /mnt/disk/usr/local/nutanix; tar -xf /mnt/svm_installer/install/pkg/nutanix-intentgateway-el7.3-release-fraser-6.5.2-stable-f2ce4db7d67f495ebfd6208bef9ab0afec9c74af.tar.xz'
2024-06-30 09:57:12,711Z INFO svm_rescue:902 hardlink all duplicate files: cd /mnt/disk/usr/local/nutanix;hardlink -c -v .
2024-06-30 09:57:12,711Z INFO svm_rescue:114 exec_cmd: bash -c 'cd /mnt/disk/usr/local/nutanix;hardlink -c -v .'
2024-06-30 09:57:12,824Z INFO svm_rescue:908 hardlink output:
Directories 1576
Objects 14804
IFREG 13129
Comparisons 3152
Linked 3113
saved 182816768
2024-06-30 09:57:12,824Z INFO svm_rescue:114 exec_cmd: bash -c 'cd /mnt/disk/usr/local/nutanix; tar -xf /mnt/svm_installer/install/pkg/nutanix-clusterconfig-el7.3-release-fraser-6.5.2-stable-f2ce4db7d67f495ebfd6208bef9ab0afec9c74af.tar.xz'
2024-06-30 09:57:12,828Z INFO svm_rescue:902 hardlink all duplicate files: cd /mnt/disk/usr/local/nutanix;hardlink -c -v .
2024-06-30 09:57:12,828Z INFO svm_rescue:114 exec_cmd: bash -c 'cd /mnt/disk/usr/local/nutanix;hardlink -c -v .'
2024-06-30 09:57:12,866Z INFO svm_rescue:908 hardlink output:
Directories 1576
Objects 14805
IFREG 13130
Comparisons 24
Linked 0
saved 0
2024-06-30 09:57:12,867Z INFO svm_rescue:114 exec_cmd: bash -c 'cd /mnt/disk/usr/local/nutanix; tar -xf /mnt/svm_installer/install/pkg/nutanix-zkcore-el7.3-release-fraser-6.5.2-stable-f2ce4db7d67f495ebfd6208bef9ab0afec9c74af.tar.xz'
2024-06-30 09:57:12,871Z INFO svm_rescue:902 hardlink all duplicate files: cd /mnt/disk/usr/local/nutanix;hardlink -c -v .
2024-06-30 09:57:12,871Z INFO svm_rescue:114 exec_cmd: bash -c 'cd /mnt/disk/usr/local/nutanix;hardlink -c -v .'
2024-06-30 09:57:12,899Z INFO svm_rescue:908 hardlink output:
Directories 1576
Objects 14806
IFREG 13131
Comparisons 24
Linked 0
saved 0
2024-06-30 09:57:12,900Z INFO svm_rescue:114 exec_cmd: bash -c 'cd /mnt/disk/usr/local/nutanix; tar -xf /mnt/svm_installer/install/pkg/nutanix-athena-el7.3-release-fraser-6.5.2-stable-f2ce4db7d67f495ebfd6208bef9ab0afec9c74af.tar.xz'
2024-06-30 09:57:16,234Z INFO svm_rescue:902 hardlink all duplicate files: cd /mnt/disk/usr/local/nutanix;hardlink -c -v .
2024-06-30 09:57:16,234Z INFO svm_rescue:114 exec_cmd: bash -c 'cd /mnt/disk/usr/local/nutanix;hardlink -c -v .'
2024-06-30 09:57:16,275Z INFO svm_rescue:908 hardlink output:
Directories 1578
Objects 14815
IFREG 13138
Comparisons 24
Linked 0
saved 0
2024-06-30 09:57:16,276Z INFO svm_rescue:114 exec_cmd: bash -c 'cd /mnt/disk/usr/local/nutanix; tar -xf /mnt/svm_installer/install/pkg/nutanix-xtrim-el7.3-release-fraser-6.5.2-stable-f2ce4db7d67f495ebfd6208bef9ab0afec9c74af.tar.xz'
2024-06-30 09:57:16,282Z INFO svm_rescue:902 hardlink all duplicate files: cd /mnt/disk/usr/local/nutanix;hardlink -c -v .
2024-06-30 09:57:16,283Z INFO svm_rescue:114 exec_cmd: bash -c 'cd /mnt/disk/usr/local/nutanix;hardlink -c -v .'
2024-06-30 09:57:16,328Z INFO svm_rescue:908 hardlink output:
Directories 1578
Objects 14817
IFREG 13140
Comparisons 24
Linked 0
saved 0
2024-06-30 09:57:16,329Z INFO svm_rescue:114 exec_cmd: bash -c 'cd /mnt/disk/usr/local/nutanix; tar -xf /mnt/svm_installer/install/pkg/nutanix-flow-1.0.1.tar.xz'
2024-06-30 09:57:16,382Z INFO svm_rescue:902 hardlink all duplicate files: cd /mnt/disk/usr/local/nutanix;hardlink -c -v .
2024-06-30 09:57:16,382Z INFO svm_rescue:114 exec_cmd: bash -c 'cd /mnt/disk/usr/local/nutanix;hardlink -c -v .'
2024-06-30 09:57:16,428Z INFO svm_rescue:908 hardlink output:
Directories 1582
Objects 14830
IFREG 13149
Comparisons 31
Linked 7
saved 159744
2024-06-30 09:57:16,428Z INFO svm_rescue:1018 Making post deployment modifications on /dev/sda1
2024-06-30 09:57:18,894Z INFO svm_rescue:114 exec_cmd: blkid -c /dev/null /dev/sda1
2024-06-30 09:57:18,898Z INFO svm_rescue:621 Root filesystem (on /dev/sda1) UUID is 89e4ab52-f4eb-4f04-9ca5-34ab504a5587 instead of ad6af956-f77d-45dd-8d44-9c006cbaddd5.
2024-06-30 09:57:18,898Z INFO svm_rescue:213 Creating Nutanix boot marker file from grub.conf ...
2024-06-30 09:57:18,911Z INFO svm_rescue:224 Wrote marker file, contents:
KERNEL=/boot/vmlinuz-3.10.0-1160.76.1.el7.nutanix.20220817.cvm.x86_64
CMDLINE='ro root=UUID=89e4ab52-f4eb-4f04-9ca5-34ab504a5587 rd_NO_LUKS rd_NO_LVM rd_NO_MD rd_NO_DM LANG=en_US.UTF-8 SYSFONT=latarcyrheb-sun16 rhgb KEYBOARDTYPE=pc KEYTABLE=us audit=1 audit_backlog_limit=8192 nousb fips=1 nomodeset biosdevname=0 net.ifnames=0 scsi_mod.use_blk_mq=y clocksource=tsc kvm_nopvspin=1 xen_nopvspin=1 hv_netvsc.ring_size=512 mds=off crashkernel=no panic=30 mpt2sas.prot_mask=1 mpt3sas.prot_mask=1 mpt3sas.hbas_to_enumerate=0 iavmd.direct_assign=1 vmd.direct_assign=1 mitigations=off console=ttyS0,115200n8 console=tty0'
INITRD=/boot/initramfs-3.10.0-1160.76.1.el7.nutanix.20220817.cvm.x86_64.img
2024-06-30 09:57:18,911Z INFO svm_rescue:241 Will try to copy /sys/class/dmi/id/product_uuid to /mnt/disk/.cvm_uuid
2024-06-30 09:57:18,911Z ERROR svm_rescue:254 Unable to create CVM UUID Marker. Error: [Errno 2] No such file or directory: '/sys/class/dmi/id/product_uuid'
2024-06-30 09:57:18,911Z ERROR svm_rescue:1043 Unable to create CVM UUID marker.
2024-06-30 09:57:18,912Z INFO svm_rescue:440 Adding /dev/sda3 to /etc/fstab to be mounted at /home...
2024-06-30 09:57:18,912Z INFO svm_rescue:114 exec_cmd: blkid -c /dev/null /dev/sda3
2024-06-30 09:57:19,047Z INFO svm_rescue:478 Adding journal log bind entry in fstab, path: /mnt/disk/etc/fstab
2024-06-30 09:57:19,047Z INFO svm_rescue:114 exec_cmd: mount /dev/sda3 /mnt/data
2024-06-30 09:57:19,137Z INFO svm_rescue:1113 Fixing permissions on /home.
2024-06-30 09:57:19,138Z INFO svm_rescue:1113 Fixing permissions on /home./nutanix
2024-06-30 09:57:19,138Z INFO svm_rescue:1138 Copying installer to /mnt/data/nutanix/data/installer/el7.3-release-fraser-6.5.2-stable-f2ce4db7d67f495ebfd6208bef9ab0afec9c74af
2024-06-30 09:57:19,138Z INFO svm_rescue:114 exec_cmd: tar -C '/mnt/svm_installer/install' -cf - . | tar -C '/mnt/data/nutanix/data/installer/el7.3-release-fraser-6.5.2-stable-f2ce4db7d67f495ebfd6208bef9ab0afec9c74af' -xf -
2024-06-30 09:57:20,648Z INFO svm_rescue:114 exec_cmd: tar -xf /mnt/svm_installer/install/pkg/nutanix-foundation-5.3.3-20221212-d90b5753.tar.xz -C /mnt/data/nutanix
2024-06-30 09:57:29,389Z INFO svm_rescue:114 exec_cmd: sudo cp -rf /mnt/svm_installer/install/ce_vibs /mnt/data/nutanix
2024-06-30 09:57:29,400Z INFO svm_rescue:114 exec_cmd: sudo cp -rf /mnt/svm_installer/install/ce_scripts /mnt/data/nutanix
2024-06-30 09:57:29,408Z INFO svm_rescue:1187 Setting up SSH configuration
2024-06-30 09:57:29,408Z INFO svm_rescue:1197 Writing out rc.nutanix
2024-06-30 09:57:29,525Z INFO svm_rescue:1288 Running setfiles.sh on the chroot: /mnt/disk
2024-06-30 09:58:41,116Z INFO svm_rescue:114 exec_cmd: sync; sync; sync
2024-06-30 09:58:47,060Z INFO svm_rescue:114 exec_cmd: umount -R /mnt/disk
2024-06-30 09:58:47,485Z INFO svm_rescue:114 exec_cmd: umount -R /mnt/data
2024-06-30 09:58:49,180 DEBUG  Marker file found, skipping assembling RAID again
2024-06-30 09:58:52,643 INFO  touching .autorelabel
2024-06-30 09:58:52,644 INFO  Creating layout file for CommunityEdition in position A
2024-06-30 09:58:52,646 INFO  Could not generate firmware config. Proceeding with imaging without it
2024-06-30 09:58:52,646 INFO  Injecting post-cluster create settings into CVM
2024-06-30 09:58:52,912 INFO  Imaging of SVM has completed successfully!
2024-06-30 09:58:52,912 INFO  Imaging thread 'svm' has completed successfully
2024-06-30 09:59:04,731 INFO  [180/2430] Hypervisor installation in progress
2024-06-30 09:59:34,761 INFO  [210/2430] Hypervisor installation in progress
2024-06-30 10:00:04,792 INFO  [240/2430] Hypervisor installation in progress
2024-06-30 10:00:34,822 INFO  [270/2430] Hypervisor installation in progress
2024-06-30 10:01:04,853 INFO  [300/2430] Hypervisor installation in progress
2024-06-30 10:01:34,884 INFO  [330/2430] Hypervisor installation in progress
2024-06-30 10:02:04,914 INFO  [360/2430] Hypervisor installation in progress
2024-06-30 10:02:34,945 INFO  [390/2430] Hypervisor installation in progress
2024-06-30 10:03:04,975 INFO  [420/2430] Hypervisor installation in progress
2024-06-30 10:03:35,006 INFO  [450/2430] Hypervisor installation in progress
2024-06-30 10:04:05,036 INFO  [480/2430] Hypervisor installation in progress
2024-06-30 10:04:35,067 INFO  [510/2430] Hypervisor installation in progress
2024-06-30 10:05:05,097 INFO  [540/2430] Hypervisor installation in progress
2024-06-30 10:05:35,128 INFO  [570/2430] Hypervisor installation in progress
2024-06-30 10:06:05,159 INFO  [600/2430] Hypervisor installation in progress
2024-06-30 10:06:35,174 INFO  [630/2430] Hypervisor installation in progress
2024-06-30 10:07:05,204 INFO  [660/2430] Hypervisor installation in progress
2024-06-30 10:07:35,235 INFO  [690/2430] Hypervisor installation in progress
2024-06-30 10:08:05,266 INFO  [720/2430] Hypervisor installation in progress
2024-06-30 10:08:35,296 INFO  [750/2430] Hypervisor installation in progress
2024-06-30 10:09:05,327 INFO  [780/2430] Hypervisor installation in progress
2024-06-30 10:09:35,357 INFO  [810/2430] Hypervisor installation in progress
2024-06-30 10:10:05,380 INFO  [840/2430] Hypervisor installation in progress
2024-06-30 10:10:35,411 INFO  [870/2430] Hypervisor installation in progress
2024-06-30 10:11:05,442 INFO  [900/2430] Hypervisor installation in progress
2024-06-30 10:11:35,472 INFO  [930/2430] Hypervisor installation in progress
2024-06-30 10:12:05,503 INFO  [960/2430] Hypervisor installation in progress
2024-06-30 10:12:35,533 INFO  [991/2430] Hypervisor installation in progress
2024-06-30 10:13:05,564 INFO  [1021/2430] Hypervisor installation in progress
2024-06-30 10:13:35,590 INFO  [1051/2430] Hypervisor installation in progress
2024-06-30 10:14:05,620 INFO  [1081/2430] Hypervisor installation in progress
2024-06-30 10:14:35,651 INFO  [1111/2430] Hypervisor installation in progress
2024-06-30 10:15:05,682 INFO  [1141/2430] Hypervisor installation in progress
2024-06-30 10:15:35,712 INFO  [1171/2430] Hypervisor installation in progress
2024-06-30 10:16:05,743 INFO  [1201/2430] Hypervisor installation in progress
2024-06-30 10:16:35,773 INFO  [1231/2430] Hypervisor installation in progress
2024-06-30 10:17:05,804 INFO  [1261/2430] Hypervisor installation in progress
2024-06-30 10:17:35,834 INFO  [1291/2430] Hypervisor installation in progress
2024-06-30 10:18:05,865 INFO  [1321/2430] Hypervisor installation in progress
2024-06-30 10:18:35,890 INFO  [1351/2430] Hypervisor installation in progress
2024-06-30 10:19:05,921 INFO  [1381/2430] Hypervisor installation in progress
2024-06-30 10:19:35,951 INFO  [1411/2430] Hypervisor installation in progress
2024-06-30 10:20:05,982 INFO  [1441/2430] Hypervisor installation in progress
2024-06-30 10:20:36,012 INFO  [1471/2430] Hypervisor installation in progress
2024-06-30 10:21:06,043 INFO  [1501/2430] Hypervisor installation in progress
2024-06-30 10:21:36,073 INFO  [1531/2430] Hypervisor installation in progress
2024-06-30 10:22:06,104 INFO  [1561/2430] Hypervisor installation in progress
2024-06-30 10:22:36,134 INFO  [1591/2430] Hypervisor installation in progress
2024-06-30 10:23:06,165 INFO  [1621/2430] Hypervisor installation in progress
2024-06-30 10:23:36,196 INFO  [1651/2430] Hypervisor installation in progress
2024-06-30 10:24:06,226 INFO  [1681/2430] Hypervisor installation in progress
2024-06-30 10:24:36,256 INFO  [1711/2430] Hypervisor installation in progress
2024-06-30 10:25:06,287 INFO  [1741/2430] Hypervisor installation in progress
2024-06-30 10:25:36,317 INFO  [1771/2430] Hypervisor installation in progress
2024-06-30 10:26:06,348 INFO  [1801/2430] Hypervisor installation in progress
2024-06-30 10:26:36,379 INFO  [1831/2430] Hypervisor installation in progress
2024-06-30 10:27:06,409 INFO  [1861/2430] Hypervisor installation in progress
2024-06-30 10:27:36,440 INFO  [1891/2430] Hypervisor installation in progress
2024-06-30 10:28:06,470 INFO  [1921/2430] Hypervisor installation in progress
2024-06-30 10:28:36,501 INFO  [1951/2430] Hypervisor installation in progress
2024-06-30 10:29:06,531 INFO  [1981/2430] Hypervisor installation in progress
2024-06-30 10:29:36,561 INFO  [2012/2430] Hypervisor installation in progress
2024-06-30 10:30:06,592 INFO  [2042/2430] Hypervisor installation in progress
2024-06-30 10:30:36,622 INFO  [2072/2430] Hypervisor installation in progress
2024-06-30 10:31:06,653 INFO  [2102/2430] Hypervisor installation in progress
2024-06-30 10:31:36,674 INFO  [2132/2430] Hypervisor installation in progress
2024-06-30 10:32:06,705 INFO  [2162/2430] Hypervisor installation in progress
2024-06-30 10:32:36,735 INFO  [2192/2430] Hypervisor installation in progress
2024-06-30 10:33:06,766 INFO  [2222/2430] Hypervisor installation in progress
2024-06-30 10:33:36,796 INFO  [2252/2430] Hypervisor installation in progress
2024-06-30 10:34:06,827 INFO  [2282/2430] Hypervisor installation in progress
2024-06-30 10:34:36,856 INFO  [2312/2430] Hypervisor installation in progress
2024-06-30 10:35:06,887 INFO  [2342/2430] Hypervisor installation in progress
2024-06-30 10:35:36,917 INFO  [2372/2430] Hypervisor installation in progress
2024-06-30 10:36:06,948 INFO  [2402/2430] Hypervisor installation in progress
2024-06-30 10:36:06,948 INFO  InstallerVM timeout occurred, current retry 0
2024-06-30 10:36:06,948 INFO  Please take a look at installer_vm_*.log inside foundation logs to debug hypervisor installation issues
2024-06-30 10:36:06,948 INFO  Terminating InstallerVM(2603)
2024-06-30 10:36:09,954 DEBUG  Using AHV-metadata iso for AHV installation
2024-06-30 10:36:09,954 INFO  Executing /usr/bin/qemu-system-x86_64 -m 32G -machine q35 -enable-kvm -drive file=/dev/sdb,cache=writethrough,format=raw -drive file=/phoenix/imaging_helper/installer.iso,media=cdrom -netdev user,id=net0,net=192.168.5.0/24 -device e1000,netdev=net0,id=net0,mac=d8:43:ae:4d:aa:a2 -vnc :1 -boot order=d -pidfile installer_vm.pid -daemonize -smp 4 -serial file:/tmp/installer_vm.log -drive file=/phoenix/imaging_helper/installer.iso-meta.iso,media=cdrom -drive file=/usr/share/edk2.git/ovmf-x64/OVMF_CODE-pure-efi.fd,if=pflash,format=raw,unit=0,readonly=on -drive file=/usr/share/edk2.git/ovmf-x64/OVMF_VARS-pure-efi.fd,if=pflash,format=raw,unit=1
2024-06-30 10:36:09,991 INFO  Installer VM is now running the installation
2024-06-30 10:36:09,991 INFO  Installer VM running with PID = 3303
  • 8 replies
  • June 30, 2024
esx=15 * 2 * 60,
hyperv=15 * 2 *60,
kvm=20 * 2 * 60,
xen= 10 * 2 * 60)
  • July 16, 2024
I had the same problem and followed this solution, now I get this error:
  File "./phoenix", line 87, in main
    params = gui.get_params(gui.CEGui)
  File "/root/phoenix/gui.py", line 1829, in get_params
    gp.allowed_actions = determine_actions
  File "/root/phoenix/gui/actions.py", line 134, in determine_actions
    hyp_packaged = get_packaged_hyp
  File "/root/phoenix/images.py", line 82, in get_packaged_hyp
    raise_on_error=False)
  File "/root/phoenix/shared_functions.py", line 99, in get_packages_path_in_tar
    ft.getmembers()
  File "/usr/lib64/python2.7/tarfile.py", line 1807, in getmembers
    self._load()        # all members, we first have to
  File "/usr/lib64/python2.7/tarfile.py", line 2382, in _load
    tarinfo = self.next()
  File "/usr/lib64/python2.7/tarfile.py", line 2317, in next
    self.fileobj.seek(self.offset)
  File "/usr/lib64/python2.7/gzip.py", line 443, in seek
    self._read(1024)
  File "/usr/lib64/python2.7/gzip.py", line 261, in read
    self._read(readsize)
  File "/usr/lib64/python2.7/gzip.py", line 315, in _read
    self._read_eof()
  File "/usr/lib64/python2.7/gzip.py", line 254, in _read_eof
    crc32 = read32(self.fileobj)
  File "/usr/lib64/python2.7/gzip.py", line 99, in read32
    return struct.unpack("<I", input.read(4))[0]
error: unpack requires a string argument of length 4
