What is the recommended snapshot age in Nutanix? | Nutanix Community
  • April 28, 2024
  • 158 views
How many days should you keep the snapshot?
It’s less about the recommendation from the Nutanix perspective as it is what you need from a business perspective.  Nutanix can keep a snapshot as long as you like with how it does snapshots it doesn’t impact performance.  Question is how far back do you want/need to be able to go back and at what point is the data no longer valid if restored.
  • April 29, 2024
Is there an expiration date?
  • 1367 replies
  • April 29, 2024
No.
But there is a NCC that will check how long the chain is. (max 35 snapshots). https://portal.nutanix.com/page/documents/kbs/details?targetId=kA0600000008fWbCAI
You can set how long you want to keep them when you setup your protection domains/policies.  You can keep X number of hourly, Y number of daily, Z number of weekly and setup your strategy that way
