Nutanix AHV VM disk accidentially deleted ... | Nutanix Community
  • April 15, 2024
  • 8 replies
  • 810 views
  • 24 replies
Ok, let’s get straight into the topic. On one of our VMs, we had 3 local disks and 5 NICs and we intended to remove 4 of the 5 NICs, which are no longer necessary.
Instead of deleting the NIC in the last row, a disk in the last row has been deleted and no, a snapshot of the VM has unfortunately not been created.
Is there any possibility to recover the deleted VM disk from this specific VM with AHV/CVM command line?
Thanks in advance for any help!
Didi7
Best answer by bcaballero
Hi @Didi7
Nutanix has a “Recycle Bin” Prism 6.5 - Recycle Bin (nutanix.com) which retains deleted VMs and volume group vDisks for up to 24 hours. If you are on a commercial version contact Nutanix Support.
Hope this helps!
Regards!
bcaballero
  • Guardian
  • 186 replies
  • April 15, 2024
Hi @Didi7
Hope this helps!
Regards!
  • 24 replies
  • April 15, 2024
Hello bcaballero, that’s how it looks like in Volume Group …
I suppose that in this case the disk of a specific VM cannot be recovered, right?
Regards!
  • 1351 replies
  • April 15, 2024
Contact support asap as the vm should be in the reclyclebin for 24 hours. (if not disabled)
  • 24 replies
  • April 15, 2024
Hello JeroenTielen,
the VM has not been deleted, only one disk of this specific VM.
So, how about this?
Regards.
  • 1351 replies
  • April 15, 2024
Dont know exactly if recyclebin is storing a deleted vdisk only. But I assume yes.
If not, then restore you backup. If there is no backup then you can consider the disk lost.
But again: Contact support ASAP ;)
  • 24 replies
  • April 15, 2024
Allright!
  • 24 replies
  • April 16, 2024
Just to inform everybody here, single deleted vdisks are sent to recycle bin.
  • 24 replies
  • April 22, 2024
Well, in fact you could even move the file with the help of WinSCP to your preferred directory instead of calling support ;)
