Hi All,
Refer Degraded Node Detection should be enable. But it could allow disable in Prism.
May we know when or why should disable Degraded Node Detection?
Best regards
Hi All,
Best regards
Best answer by ahmad.jamali
If we look at the feature itself, it gets triggers when a node can be in a partially-available state due to :
so it is better to have the option enabled unless you have some issues (like network problem which you are aware of it)in your environment which you know the source is not Nutanix and you might want to disable this option (which I do not recommend).
