Volume Groups - Which API v3 or v2 & Ansible Module Nutanix NCP | Nutanix Community
  • August 22, 2023
  • 189 views
Hello Everyone
I have been building Ansible Playbooks to automate Nutanix VM builds and I have the need to create and attach a volume group to some of the VM’s.  The Nutanix NCP module from Ansible Galaxy has been pretty much the only module I could locate that really handles the vm creation well.  What I have found is that depending on where you go there are conflicts in whether or not version 3 or version 2 of the API is supported.
While using the API explorer on Prism Central it is shown as volume_groups and appears exposed.  When reviewing docs and next.nutanix, various API information it appears it should work but doesn’t and I can’t seem to locate any good examples.
Anyone here willing to share code or direction on what they have working for volume group creation and management.  I am currently on working with 2 clusters with Prism Central deployed.  I am hopeful I can find a functional example of ansible or api calls that manage volumes and thank anyone in advance for their help.
Version Information
Version 6.5.3.6 LTS
NCC Version 4.6.4
LCM 2.6.1
sl.farhanparkar
Hi Glenn,
Had you look at https://www.nutanix.dev/.
F>P
