Nutanix Calm API request returns incorrect task UUID | Nutanix Community
  • August 3, 2023
  • 342 views
I am currently using Nutanix Calm API v3. After creating a crash-consistent VM recovery point using the POST endpoint /api/nutanix/v3/mh_vms/{vm_uuid}/snapshot and verifying that it exists on Prism Central, I attempted to revert the VM to this recovery point using the POST endpoint /api/nutanix/v3/mh_vms/{vm_uuid}/revert using the recovery point uuid in req body. The response has 200 status code but the task reference returned has task_uuid value of ‘something’. I also cannot see any alerts on PC indicating that the VM revert task has been attempted.
May I know if anyone has experienced this issue before and how I might rectify this issue? Im not sure how to proceed since the API request appears to be successful. In particular, I would like to understand the circumstances under which Calm API returns tasks with uuid value of ‘something’. Thanks!
Best answer by santhosh.vijayan-71850
@Phianne Calista, the mh_vms route is not a part of Calm apis, it is owned by the AHV team. Digging a bit deeper, it looks like mh_vms/vm_uuid/revert api is not supported at all. Please check here on how to use vm_recovery_points endpoint to restore https://next.nutanix.com/how-it-works-22/restore-ahv-vm-via-api-v3-40357
If you need info on the self service snapshot/restore feature please have a look here https://next.nutanix.com/community-blog-154/nutanix-calm-introducing-snapshot-and-restore-actions-40041
