AOS Installation Failed With Error | Nutanix Community
  • February 16, 2023
  • 791 views
apiwat_sang
Hello All,
I tried to install AOS 6.5.x with foundation 5.3.2 and nutanix but I faced from some issues.
please find the below logs for reference
2023-02-16 09:10:32,277Z INFO [1081/2430] Hypervisor installation in progress2023-02-16 09:11:02,318Z INFO [1111/2430] Hypervisor installation in progress2023-02-16 09:11:32,358Z INFO [1141/2430] Hypervisor installation in progress2023-02-16 09:12:02,371Z INFO [1171/2430] Hypervisor installation in progress2023-02-16 09:12:32,413Z INFO [1201/2430] Hypervisor installation in progress2023-02-16 09:12:32,595Z WARNING Hypervisor installation takes longer than usual2023-02-16 09:13:02,453Z INFO [1231/2430] Hypervisor installation in progress2023-02-16 09:13:32,486Z INFO [1261/2430] Hypervisor installation in progress2023-02-16 09:14:02,525Z INFO [1291/2430] Hypervisor installation in progress2023-02-16 09:14:32,563Z INFO [1321/2430] Hypervisor installation in progress
Best answer by bcaballero
Hi @apiwat_sang
What about the SATA-DOM?
Is it ok?
AHV is installed on that drive and maybe is not working properly.
Regards!
  • 33 replies
  • February 16, 2023
This could be a list of possible issues - what hardware are you installing on? Is your network all okay with all pre-reqs for foundation in place? There's not much to go on in that log, have you downloaded the full log from foundation tool?
Si
apiwat_sang
  • 7 replies
  • February 16, 2023
Si
Hardware Nutanix NX-1050 (EOL Model) I usage for lab test only. I'm only having problems with 1 node out of 3 nodes.
apiwat_sang
  • 7 replies
  • February 16, 2023
Addition log:
2023-02-16 09:31:33,794Z INFO [2343/2430] Hypervisor installation in progress2023-02-16 09:32:03,836Z INFO [2373/2430] Hypervisor installation in progress2023-02-16 09:32:33,877Z INFO [2403/2430] Hypervisor installation in progress2023-02-16 09:32:33,886Z INFO InstallerVM timeout occurred, current retry 02023-02-16 09:32:33,908Z INFO Please take a look at installer_vm_*.log inside foundation logs to debug hypervisor installation issues2023-02-16 09:32:33,917Z INFO Terminating InstallerVM(8455)2023-02-16 09:32:36,941Z DEBUG Using AHV-metadata iso for AHV installation2023-02-16 09:32:36,951Z INFO Executing /usr/bin/qemu-system-x86_64 -m 32G -machine q35 -enable-kvm -drive file=/dev/sdg,cache=writethrough,format=raw -drive file=/phoenix/imaging_helper/installer.iso,media=cdrom -netdev user,id=net0,net=192.168.5.0/24 -device e1000,netdev=net0,id=net0,mac=0c:c4:7a:0c:f6:9f -vnc :1 -boot order=d -pidfile installer_vm.pid -daemonize -smp 4 -serial file:/tmp/installer_vm.log -drive file=/phoenix/imaging_helper/installer.iso-meta.iso,media=cdrom2023-02-16 09:32:37,070Z INFO Installer VM is now running the installation2023-02-16 09:32:37,082Z INFO Installer VM running with PID = 112492023-02-16 09:33:07,122Z INFO [30/2430] Hypervisor installation in progress2023-02-16 09:33:19,157Z INFO Installing AHV: Installing AHV2023-02-16 09:33:37,163Z INFO [60/2430] Hypervisor installation in progress2023-02-16 09:34:07,204Z INFO [90/2430] Hypervisor installation in progress
bcaballero
  • Guardian
  • 186 replies
  • February 16, 2023
Hi @apiwat_sang
Is it ok?
Regards!
apiwat_sang
  • 7 replies
  • February 16, 2023
bcaballero wrote:
Hi @apiwat_sang
Is it ok?
Regards!
Hello, thank you for your advice. I will be checking a SATA-DOM.
