I want to migrate Prism Central VM AHV cluster to ESXi on Nutanix cluster, please suggest the easiest way to migrate with no impact.
Prism Central Migration from AHV Cluster to ESXi on Nutanix Cluster
Best answer by Kcmount
Hello
I hope you're well.
Please review the following information, hopefully it will map out the process: Prism Central Disaster Recovery
I feel this, whilst a DR process, will be the most logical way forward for you, especially with cross hypervisor.
