How To Take a Snapshot ? | Nutanix Community
I already following nutanix from youtube and KB but didn’t find any Take a Snapshot menu.
Does the take a snapshot have different method now ?
Best answer by Tirtayudha
Already discuss with SRE, cause i’m use VMware as hypervisor the only solution is using playbook
Moustafa Hindawi
Your available options depend on the VM status, type, and permissions. Unavailable options are unavailable.
  • September 9, 2022
