Nutanix TOR Switch Spec | Nutanix Community
Is there any specific requirement port speed on TOR Switch for Nutanix Cluster running NVME + SSD storage? Is still good running 10Gb Switch to cover NVME + SSD performance? Thanks
Best answer by JeroenTielen
Best practices is to use the Leaf and Spine setup. And the TOR swichtes must be seen as the Leaf switches.
A picture is worth a thousend words ;)
Here you can find the best practices for the network configuration: Network Configuration Best Practices
  • 11 replies
  • August 2, 2022
Hi @JeroenTielen
Thanks for your information...but my concern is more about specification of TOR Switch to maximize performance of Nutanix Storage using NVME + SSD. Is it enough using 10Gb switch or must use more than 10Gb like 25Gb/100Gb? Thanks
  • 1363 replies
  • August 2, 2022
StuB
  • 19 replies
  • August 3, 2022
Hi Hendra, I don’t think there is any requirement to use anything greater than 10G for a Nutanix deployment even where NVMe is used.  You may want to consider faster if you think the network could introduce unwanted latency, but this will depend on the nature of the workloads.
