X-Ray VM Availability test failure, Physical not left powered off | Nutanix Community
  • March 31, 2022
  • 111 views
All,
I ran the VM HA test failover; similar to another user, here Nutanix X-Ray VM High Availability Test timeout I got the 120 seconds timeout. So I raised a ticket. However one issue I did have is the powered off host was not powered back on again. All validation tests when I discovered the targets were good. I have included this in the support ticket for now, but wondering if anyone else has seen this? Older G5 Nutanix, 3 Node cluster, AOS 5.20.3, PC 2022.1.
  • April 6, 2022
Hi @SiW-Ts
We are looking at the VM HA test timeout issue reported earlier. Can you send us the logs from your tests? Instructions and a place to upload the logs are here: https://forms.gle/modFABFaFu3f8NHs8
Raj
