How do you delete a recovery point of a VM that no longer exists? | Nutanix Community
  • January 14, 2022
  • 6 replies
  • 1817 views
How do you delete a recovery point in Prism Central of a VM that no longer exists?
  • January 21, 2022
Within VM Recovery Points in Prism Central, select a VM that had Recovery Points and there will be a Delete Action.  Wonder if there is a scriptable way to do so?
  • 30 replies
  • January 22, 2022
There is a scripted way of doing this through nuclei utility of PC. We suggest calling into Nutanix support if you need to delete multiple recovery points.A couple of them can be safely deleted through Prism UI.
Thanks and Best Regards
  • January 10, 2023
Hello, can you share with us scripted or cli way to delete recovery points.
We have nutanix support but no luck with SRE.
Using pc.2022.6
  • November 23, 2023
@Haritha Andal i am very much asking for help in this matter. We want to delete multiple recovery points wich are in different VMs
Using for now pc.2023.1.0.2
  • January 8, 2024
How do you delete it if the VM no longer exist?  When I select the recovery point, the only options I get are Clone, Revert, Replicate.
Moustafa Hindawi
Hello @bkbandit
Run: nutanix@CVM:~$ ncc health_checks hypervisor_checks orphan_vm_snapshot_check
the snapshot UUID will be shown as below:
INFO: Found 3 orphan VM snapshot(s): ['0477ee8f-60a0-4cdf-9516-9ba078a70920'
Then delete the snapshot/s
nutanix@CVM:~$ acli snapshot.delete 0477ee8f-60a0-4cdf-9516-9ba078a70920
