Hi All
Follow the link,
after the AHV was upgraded to 5.19 or lateer, the br0 of OVS was replaced with vs0,
If br1 or br2 can coexist or need to be manually migraded,
does anyone have some experience .
Thank you
Hi All
Follow the link,
Thank you
Best answer by UPX
Hi Wei Cheng,
from 5.19 onwards you have 2 choices to manage the network.
The first is to manage that via Prism GUI under network configuration.
The second via CLI with new commands.
BUT, when you do the upgrade to 5.19 or a foundation with the same version you have to configure the network via GUI because this takes precedence over the CLI configuration with the old commands.
I guess here you can find some useful info about this and also about some new CLI commands using acli.
https://portal.nutanix.com/page/documents/details?targetId=Web-Console-Guide-Prism-v5_19:wc-network-management-wc-c.html
Hope this helps.
