Foundation Fatal Error | Nutanix Community
Hello Friends
How are you? Currently i am trying to foundation A Nutanix 3 node environment but after the foundation process begins it will halt at “waiting for the installer to boot” stage with “fatal” error warning i don’t know what is causing the error can anyone tell me something.
I have attached screenshots of errors and process.
Michael.Manuele
Hi..  Can you please ensure you can access each node via the IPMI interface.  It looks like there might be an issue accessing the 192.168.0.150 node via IPMI (192.168.0.130).  I would start by ensuring all the physical connectivity is correct and you have link lights on all the ethernet ports and then trying pinging  them all from the foundation VM.
  • 30 replies
  • August 30, 2021
Hello @bereketsolomon Make sure foundation VM can reach the IPMI interface. As Michael mentioned, please check physical connectivity. Turn off the firewall on foundation VM and make sure you use 10G ports on the node. In a couple of cases with similar error, the issue was with VLAN trunking and ports.  Port 80,443 and 623 should be open between IPMI and foundation VM.
yes i can access the IPMI interfaces.
yes the ports are open and still the same am guessing may be the phoenix ISO has crashed?
It’s trying to reach out on 10Gig uplink network not reachable. Please check switch ports are enabled and VLAN trunk configured.
I am having the exact same error. And we are using our own switch.
Do we know what was the problem?
Thanks!
Thanks!
yes in my case the phoenix was crashed so try to install the phoenix manually then create the cluster from Putty by logging in on the CVM
While pushing the ISO image through CVM IP address are not reachable the whole installation will be failed. Please check switch port configuration, IPMI interface and uplink connectivity from host to switch port.
  • 1341 replies
  • October 26, 2021
First things first, disable the firewall on the machine where foundation is running.
  • 1341 replies
  • October 27, 2021
OKe a bit more side information.
It looks like the foundation machine can talk to your IPMI as you can see on this screenshot:
But your foundation machines never received the talk back from phoenix that it is booted. What I normally do during this stage is open an extra console session to the node to see the actual status. Probably it is booted into phoenix but can't talk to foundation. And this has to do with your firewall on the foundation machine.
TTI excalibur
TTI excalibur
Thanks!
Hi @bereketsolomon , do you have a link for this for the proper procedure?
hello,
i am also having the same issue, i did perform the deployment through portable foundation as well foundation VM. both foundation VM & portable foundation system can access the IPMI interface & port 80, 443,22 is also open ( tested with telnet)  only pot 623 is not getting telnet ( there is no access list configure & since its internal traffic, no chance to block on firewall, Can you please confirm how to check the port 623 is open or not ..
  • 1341 replies
  • April 10, 2024
Foundation machine also needs to talk to the given ip adressess not only ipmi. And if you run portable foundation, make sure you disable the firewall on the machine where foundation is running.
  • November 28, 2024
When the console is booted into the phoenix how to make sure it can talk to the foundation (e.g. download tarball.gz files and so on..). My one always failed during host/ahv installation. It probably failed to talk back with foundation and sometime foundation fatal error showing it failed during waiting installer to boot up. Are those ipmi/bmc issue?
  • 1341 replies
  • November 28, 2024
Open the console from the node and watch what it is doing. Then you can see what is happening.
