Firmware version is S560301N out of date | Nutanix Community
I’m getting a:
Firmware version is S560301N of Innodisk host boot disk/ dev/…. of model SATADOM-SL 3IE3 V2 is out of date.
AHV Environment
Dell referes to the Nutanix support.  Can someone post the actual download link/ the download area? Thanks,
aluciani
Forum|alt.badge.img+34
  • Chevalier
  • 348 replies
  • August 25, 2021
Hi @Dennis112233
Something like this you will want to open a ticket with support and the team can provide you with guidance.
  • 30 replies
  • August 25, 2021
Hello @Dennis112233
Please run LCM inventory and see if there are any new versions that you can upgrade firmware and other components. When upgrading firmware, you will want to be careful about the upgrade order. Here’s the recommended upgrade order guide.
The LCM fetches the firmware updates itself you won’t manually need to download the ISOs.
  • 10 replies
  • August 26, 2021
It’s an isolated environment.  I have to load the firmware update manually.
  • 30 replies
  • August 26, 2021
Hello @Dennis112233 Please let me know if the following doc helps: https://portal.nutanix.com/page/documents/details?targetId=Hardware-Admin-Guide:bre-manual-firmware-update-c.htmlThe doc should contain a link to KB that has firmware download links.
