How to update network on windows guest running on AHV? | Nutanix Community
  • February 18, 2021
  • 82 views
We have created a new vlan for windows 10 VM and I wanted to update existing network to new network. I was not able edit the existing network and choose the new one, it is grayed out.
Do I need to delete and re-add new nic and choose the new network? For ESXi, you simply browse the network and select the one you want and save it.
Best answer by Alona
For an older AOS version, you would re-create the NIC or power off and use aCLI to update the NIC see this thread.
bbbburns
Forum|alt.badge.img+14
  • 60 replies
  • February 18, 2021
What AOS version are you running? You should be able to change the network in the most recent versions (I believe in 5.11 and later).
  • March 2, 2021
Hey Steve,
starting with AHV-20201105.12 and AOS 5.19 you can change nic networks like in vsphere or hyper-v.
Serge
  • March 8, 2021
