Powershell Users & Roles | Nutanix Community
  • February 4, 2021
  • 170 views
I’m relatively new to Powershell and have been looking for the cmdlet get the Role Mapping information from a cluster. I’ve no issues connecting using Powershell I just cant find the correct cmdlet which will allow me to get the Role Mappings. My apologies if I haven’t placed this is the correct group.
Best answer by AnishWalia20
hey @AaronT here are few resources on powershell.
https://portal.nutanix.com/page/documents/details?targetId=API-Ref-AOS-v56:PowerShell-Cmdlets-Reference
https://portal.nutanix.com/page/documents/details?targetId=API-Ref-AOS-v5_17:ps-ps-cmdlets-c.html
I hope the above helps. :sweat_smile:
Let me know if you need anything else.
AnishWalia20
  • 201 replies
  • February 5, 2021
  • February 5, 2021
Thanks AnishWalia20.
Looking through the CMDLETS I cannot find the one that would provide me with this info
I will keep looking.
AnishWalia20
  • 201 replies
  • February 6, 2021
Hey @AaronT . Sure, maybe Powershell cmdlets don't support this function of getting the Role Mapping information.
In the meantime, if you find anything do share it with us and I will keep looking too.
