Nutanix replication or recovery with volume group | Nutanix Community
  • December 16, 2020
  • 1102 views
Hi Everyone,
I want to know what nutanix version can do replication or leap recovery plan with volume group (iscsi)?
I currently use the CE version for testing ,my Nutanix CE and PC version are NUTANIX 20190916.276.
I'm testing the iSCSI space of volume group mounted on Windows Server,
then execute the plan of leap failure. However, after my windows server fails to DR, there is no iSCSI space on the windows server, and I do not see that the volume group is sync to DR.
Is there a problem with my configuration, or is the CE version not supported at present?
Has anyone ever done this test?
Thanks.
Best answer by Alona
Hi Wei Cheng,
If I understand your question correctly this should answer it Limitations of Asynchronous Replication (Leap with Single Prism Central) 5.17
Volume groups (VGs) are not supported.
Same for the 5.18.
  • December 17, 2020
Hi Wei Cheng,
Same for the 5.18.
