Phoenix re-image fails on minimum_reqs.py | Nutanix Community
  • December 3, 2020
  • 276 views
minimum_reqs.py
The NICs are connected, not sure why its failing. Anyone knows? I have tried with foundation 4.6 and 4.5.4.2 . The Nics are connected an Intel with dell firmware 19.5.12. Existing cluster is running fine with same specs.
Neel Kotak
  • 96 replies
  • December 4, 2020
Hi @quacksh0t
These errors are spotted if connected gbic transceivers in our 10gb interfaces. This can cause ethtool report 10/100/1000 speeds inaccurately, causing phoenix / foundation to fail with the error shown in the description.
Could you. please confirm the speed of the interface with the help of the following command
ethtool eth<interface>
Also please confirm if the drivers are loaded correctly with the help of the following command
lspci -m
  • December 4, 2020
Thanks Neel.
I used foundation 4.4.4 and the re-image actually went through! I have double checked, and the speed is 10gb.  Not sure why this version worked and the latest didn’t..
