Prism Date Format | Nutanix Community
Prism Date Format
  • May 13, 2020
  • 1839 views
bhavin7array
Hi, How can I change the date format on Prism & CLI
it's currently mm/dd/yyyy and i'd like to make it dd/mm/yyyy
Best answer by diegodco
Check the following article:
https://portal.nutanix.com/page/documents/details/?targetId=Prism-Central-Guide-Prism-v56:mul-cluster-localization-pc-c.html
