How to avoid Self Service Restore icon when feature is not enabled | Nutanix Community
  • November 7, 2019
  • 1365 views
AOS is in 5.10.8, We need to install NGT on Windows Server 2016 with only VSS feature enabled and not SSR. However, after installation, even though the SSR feature is not enabled, there is the SSR icon on the desktop. It can be opened and bring us to “http://localhost:5000”. I can understand that the feature is not active but I would like to avoid having it displayed on the desktop. How to avoid to have this on the desktop ? (I’m looking for another way than deleting the icon manually after NGT installation). What about this local web server ? Could it be stopped ?
Best answer by Alona
Unfortunately the option to perform selective installation of NGT  is not available at this time. Same goes for the opened ports that are provisioned for the SSR feature to work.
  • November 8, 2019
