Image Configuration - Error occurred while getting image list
I have been getting the below error when i select image configuration. When i do image.list i could see the images in acli.
image.list
Image name Image type Image UUID
Nuatnix Xtract kDiskImage f3b18c26-e461-44af-b3e1-bc295078fe40
Virto-Windows kIsoImage ffcbbf1d-7380-4803-af4c-fd16fa6795f3
Windows_2016 kIsoImage 15ec4036-703b-471d-9887-3cb6a569426e
[h4]Error occurred while getting image list[/h4]
image.list
Best answer by greatquux
nm - i figured it out - i had removed a storage container and some images were stored there - if you doimage.get
on an image that was stored on a container you removed, it will throw an error. but you can do image.delete on it, and after i removed all of them, GUI works again to get the image list.
