question Detailed information for disk_usage_check | Nutanix Community
  • June 8, 2018
  • 1119 views
AOS 5.5.2
HypervisorNutanix 20170830.120
From one of several nodes A warning alarm occurs.
The message is as follows.
Detailed information for disk_usage_check:
Node xxx.xxx.xxx.xxx
WARN: /home usage at 84% (greater than threshold, 80%)
Refer to KB 1523 (http://portal.nutanix.com/kb/1523) for details on disk_usage_check
I checked that node into CVM.
I deleted the download file used for the upgrade, but it is still 82%, but I do not know what to clean up.
I want to know the solution.
Or should I open the case? I wonder.
Please ask for advice.
Thank you.
Best answer by aluciani
Hi @yhcho
You should open a support case, and when you have the issue resolved share the solution here so others in the community can benefit from the knowledge. Thanks
aluciani
Forum|alt.badge.img+34
  • Chevalier
  • 348 replies
  • June 10, 2018
Hi @yhcho
