After a failed upgrade that resulted in a failed node, we reinstalled the node and added it as a remote site so we could migrate to it and reinstall the other nodes.
When I added the site on the old cluster it works as expected, but on the reinstalled node I cant add any vStore Mappings and are instead greeted with this message "Remote Datastores are either not configured or not accessible."
When I run ncli> remote-site list on the reinstalled node I get:
Status : unreachable
and on the old cluster:
Status : relationship established
Is there any log output/command that could help me troubleshoot this further?
Remote Site vStore Mapping not accessible
Best answer by JFuller
I fixed this by using ncli:
ncli> remote-site rm name="NTNX02" force=true
View originalncli> remote-site rm name="NTNX02" force=true
