Supported upgrade Broadcom VMWare on HPE | Nutanix Community
Nutanix Compatibility matrix shows that they support the next version of VMWare but there is no 1-click upgrade. I am running on HPE machines and we have been burned in the past where if we use an “off the shelf” ESXi .iso from VMWare it breaks the linkages from VMWare to Nutanix.  We can only use an HPE branded (drivers included) VMWare .iso so that the Nutanix tools (vsan and VAAI) work.
Broadcom has taken over VMWare they do not supply HPE branded .iso for upgrades according to the Broadcom case I opened.
Nutanix does not supply upgrade paths for VMWare according to the Nutanix case I opened.
HPE does not integrate with Broadcom anymore according to the HPE case I opened.
How do you upgrade your VMWare deployment on a Nutanix linked Prism Central without a full rebuild?
Be the first to reply!
